06 yz250f running lean
I Just put a pro circuit t-4 silencer on my bike and I took it for a ride with the stock jetting, on the high rpms it seemed to break up so I went from a 178 main jet to a 180 and the problem seemed to go away. So I pulled the plug after riding it for 15 minutes and it was whitish-grey so i'm thinking its running lean and it has very little popping when I let off the gas from wide open. I think its running lean on the pilot jet, pro circuits website says to run a 45 pilot jet and a 65 leak jet. Thats the jetting specs for the 06 which I have but I have a 07 system on it. For the 07 it says to run a 42 pilot jet and a 60 leak jet. Do you think that the leak jet and pilot jets just need to be changed??? And pro circuits website says to have the fuel screw at 2 turns out which I have done.
Thanks,
mike
No offence here, but you have an 06 bike, go with 06 specs. All you have is the 07 pipe, it doesn't change the bike to 07.
