newbie here =)
Hi All,
This is my first post and i just thought i would say "Hi" and all that good stuff. I just recently acquired a 2003 KLX 400 SR and found out about this forum from another motorcycle forum i belong to ( I've already spent about 7 hours reading tons of posts and trying to learn as much as possible about my new machine here. :thumbsup: So, after doing some reading here, i am now petrified and paranoid about the CS sprocket seal issue, the primary nut and the cam chain tensioner! :thumbsup: Guess i have some issues to address with this bike! :cheers:
While i am new to this bike, i have been riding motorcycles (streetbikes) for about 25 years and i try to do as much of my own maintenance and repairs as my ability and tools allow. I am aware of the search function and the FAQ's of this site, so i will try not to ask stupid questions too often, but hey, i make no guarantees, LOL !
I recently moved to the Tucson Arizona area, and would be thrilled to meet up with any other members of this forum who happen to live nearby or even semi-nearby. I know there is lots of off road riding to be done around here, but i am not very familiar with the surrounding areas yet, so it would be cool to meet up with some more experienced off-road riders and do some trail riding and whatnot. Or, if anybody is up for sportbike riding, I'm THERE!!!:busted:
welcome to TT.:thumbsup:
ex ZX12 R owner here , the DRZ is a fine motor cycle .
want to do some awesome riding ? travel to down under i will show you around .
Welcome to the club. Sounds like you have your mind right and will have a lot of fun both with your new bike and here on TT. :thumbsup:
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
