2006wr450f
What did you do to your WR today?
4,514 posts in this topic
This what I have for pics. Decals from eBay.
Thanks for the pics. For some reason I thought you had a 2012. I', looking for some graphics for my 2012 wr450 and just wanted to see some bikes with graphics.
On my 2013 WR450F I installed a Devol Link,  it dropped the rear 1 1/4", & greased the rear suspension linkage. While I was at it I pulled the triple clamps and greased the steering head bearings. I suspect everyone already knows this but from the factory Yamaha puts just enough grease on parts so they do not corrode in the crate during the boat ride from Japan. What I did notice on the lower steering head bearing was several very fine, 1/8" long aluminum shavings on the bearing. I suspect from pressing the lower bearing onto the aluminum stem. I like to used Belray water proof grease on all points. I have been using it for years and it seems to remain even when I use a pressure washer. I should get my seat back from being lowered by SDG Monday. This should allow me to touch both feet on the ground while in the saddle. I can't wait to ride it.
Edited by DRZ04
After installing the link & the cut down seat now I can touch the ball of one foot and the tip toe of the other on the ground. It gives me confidence that I will be able to dab a foot if needed on the trail to keep from falling.
Took forks apart, now just waiting for the seals to come in and turns out i need new rubber stops in the top of the fork -.-
Put a newer carb from a 2004 WR450 on my 1999 WR00. Got it all bolted up and fuel started pouring out the float bowl. Got a new gasket the next day and it still leaked a little but it was slowed enough to at least see if it would run. It wouldn't idle so I bought new jets and a different brand float bowl gasket that actually stopped the leak. Put new jets in, still wouldn't idle with fuel screw adjustments so I put in a larger pilot jet. Got it to idle but with some popping and hanging idle, adjusted the fuel screw and smoothed it out. took it for a test ride and there's a little stutter right off idle and doesn't seem to pull as hard but I think the big bad bog is gone. My main goals with updating the carb were getting rid of the bog and getting it to cold start easier. I'll fire it up again tomorrow when it's cooled down and see if that is better now, but I know it still needs some fine tuning. Lessons learned for a carb swap: replace the jets no matter how good they look, K&L gaskets are shit.
I got one of the last 6.8 gal safari tanks in the mail for the 03-06 wr450. all I can say is WOW. Holds the gas much lower thank the acherbis 6.6 and looks much smaller. Pics coming soon. Safari discontinued this tank but there are a few floating around at dealers. I got it for 450 on close out.
Rode it, wrecked it, and layed on the couch the rest of the day in pain. Yes the bike is ok, but after taking my handlebars straight to the ribs it is a little tough to breathe
Installed a quick turn throttle and new grips as well as ...
Re-greased the linkage, swing arm , wheels and steering bearings.
After putting them in two years ago all of them were perfect still except
the steering bearing , lots of water came out when I disassembled the T/C.
Water proof grease is a must have.
 All back together and ready to load in the morning for a ride.
Edited by still2smokin
1 person likes this
I highly recommend a quick turn throttle tube,  very noticeable on long hill climbs with whoops.
2 people like this
Blue on top of the hill. Red a no go. Lone tree cyn.
Old jet plane crash.
2 people like this
Where is that plane crash? is looks like a BD10. I had a friend crash his BD10 he didn't make it.
I put mirrors on the bike today. Got them off eBay for under $20.00 including shipping. They are bar end mirrors that I mounted to face inside. The brackets are aluminum. No vibration, and they are tucked in out of the way of *things*, though the next time I go over the bars they might get hit by me...
The pics dont really show it, but the mirrors are convex and have great coverage side to side.  They replaced my one Acerbis plastic mirror.  Pretty happy with them.
I am running a stock brake lever on the brake, so moving the lever in wasnt an issue.  I have an ASV clutch lever and it is a very tiny bit short now since I have the light switch in the way, but not enough to do anything about.  I think I could grind down the mirror bracket if I wanted, and probably get 1/8 to 3/16 more lever. Or just switch back to the stock clutch lever...
cheers-
Dustin
Edited by SurfaceToAir
  • Similar Content
    • By aminem
      I have never ridden 2t dirt-bike , i start my dirt bike adventure this year with a 4t yz450 and i love this sport. now am interested to test 2t cross and want to use it for enduro and MX. are this bikes ( yz250) good for both enduro and MX use !? i heard that yz250 is the same from 2006 up to 2016 and have no change . what about honda cr250r !? which year and model of this two brand worth owning !?
    • By Gearhead20
      Hey guys,
      Im looking to buy a new Yamaha 2 stroke within the next couple weeks but i cant decide whether i would be happier with the 2018 yz 250 or the 2018 yz250x. Heres my riding background. Ive been riding for 15 years, I raced in the A class for 5 years until money got tight and i gave up racing all together. Since i then I realized how much fun single track riding is and just free riding with the buddies. I still occasionally ride tracks but about 80% of my riding is trails. I live in Michigan and if you have ever ridden in Michigan then you know the trails can get as rough as a motocross track. My local trails have sand whoops that i would compare to
      REDD-BUUUDDDS sand whoops.
      Ive never owned a "trail" bike ive always taken my race bikes and made them into "trail" bikes. My last bike being a Yz125.
      That being said i know all the mechanical and technical differences between the 2 bikes. Im a bit worried that the 250x just wont have the racey feel when im riding. Im also worried then when i do take it to the track the suspension will be a bit soft and the mellow hitting powerband will not allow me to seat bounce the big whoops. But now the standard yz250 might not have enough low end to help me skate through wet black slick dirt and the suspension might be a little to "non responsive" per say in studder bumps. Can you guys give me any sort of guidance.
      If you would like to check out my riding style on YouTube check out : "Yz125 2 stroke Shredding Michigan Enduro Trails."
      Thanks Guys
    • By cfunk713
      2016 yamaha yz 450f, yoshi pipe, rekluse clutch, renthal twin wall bars, renthal chain and sprockets not installed still has stock chain and sprocket that's how little its been riden, boysen super cooler pump, wc radiator guards, pc lowering link.
    • By Caleb Kittrell
      I just bought a 2005 YZ 125 with a ported cylinder & a decked head. I am a trail rider, I do not race. What are my service intervals for top-end rebuild? What brand do you recommend?
    • By nluni0330
      I am selling my California Plated YZ426F. This bike is very rare because there are not many CA plated YZ426F's and it is in great condition. The bike has been garaged and well maintained. The bike was just serviced and completely gone through. White Brothers Exhaust/spark arrester, Pro Taper handle bars, steering stabilizer.
      New kickstand, new graphics, new fenders, new LED headlight and turn signals. Front and rear shocks have been serviced by ESP. The bike starts right up and runs well. I have a desert tank, paddle tire, stator, turn signals and other original parts I will include with this purchase. Title in hand. Best way to reach me is by email. Second best way is by text. $3400 OBO
