2006wr450f
What did you do to your WR today?
4,514 posts in this topic
why mod it right away, why not ride it a while and then add stuff so you know what the effects were? are you so fast that you ride to the full potential of the bike?
Dont know if you were post to me or now, but here it goes.
First off, Im only installig the GYTR AIS removal kit. And the
greasing all the bearings.
Not sure if your question was serious or sarcasm either, but
in the event it was sarcasm I have a question for you. How
do you know that I havent owned 5 other 450's? Why does
a new bike have any indication of someones riding ability?
Just curious......:lol:
To give you a free answer to my question, this is my first 450,
and that is why I will not be performing any intake or exhaust
mods at the moment. :)
Just make sure you do all the free mods, which I assume you are doing now.:lol:
Put a GYTR brake pinch on. I'll do anything to save a little weight :lol:
Found an area within 1/2 hr of my house with no snow on limited trails. Had a good couple days of riding :)
This is what the snow looks like in my yard still :lol:
finished the oil swap. only took about 8 hours lol. swapped the spark plug for an iridium ix ngk cr8. There seems to be a collet on the plug which im guessing raises the compression ratio slightly. The exhaust note is different. also looked at the stock cr8 and wondered how much it be worth on the international coal exchange. I guess thats why she was tough to start. Refitted the engine guard and gave her a clean.
my wr 426 is super picky with the spark plug. if i give it gas while cranking once, it's fouled and i have to change it for sure. i went through 4 spark plugs this summer.
if you've had 5 450's of the same year, then i retract my statement and wonder why someone would go through them that fast, but you know, whatever floats your boat. what you said makes sense. the wr bearings and linkage is undergreased from the factory.
I had a couple hours to kill this afternoon...So I polished up for some BLING....
Hi.
What does GYTR stand for (it's on your bike) and why is it white, not blue?
Hi.
Genuine Yamaha Technology Racing
GYTR - Genuine Yamaha Technology Racing
Those are some graphics I got from the Yamaha shop (they are for YZF)
The bike came with blue plastics. I like the white look better so I switched them out and recovered the seat with a YZF special edition cover.
Very nice custom-cruiser. A few questions please. Where did you get the white plastic, where did you find the trick gas cap, and how did you polish the frame? Thanks.
im thinking about painting my frame next winter, how hard was it to do?
not to hard to do i done mine in a weekend alot of the time was taken up by taking the bike apart. but im a paint sprayer so painting it was real easy :)
chipwich
Polisport and Acerbis both make White plastics for the WR. look for one of these brands if you make the switch.
http://www.thumpertalk.com/forum/showthread.php?t=501912&highlight=plastics
Mine are actually 07' YZF plastics and the front fender bolts right up. The radiator shrouds bolt right up to my 3 gal IMS YZF gas tank. The rear fender I had to fab a bit to make it work but it has been fine for over a year.
Gas cap was an Ebay find for 28.00 (IMS cap)
To Polish Aluminum go down to your local ACE hardware pick up a sheet of 320 grit,400,600,800,&1500 grit metal sand paper. Total investment about 7.00.
I then cut about 8 2"x2" squares of each grit then use four of ea grit on each side working up to the 1500. Then you get a 3" buffing wheel put it on a cordless drill with either some buffing rouge or just some metal polishing paste. Buzz that over everything real good then buff out with a soft terry cloth. The more prep you do the better it will come out but we're not building a piano here so some imperfections are fine.
Good luck and have fun with it!!!!!
Bought new higher Pro Taper bars, Acerbis rally pro hand guards and new grips! Waiting for them to arrive then all I need is to decide on which grip warmers and I'll be ready to go again!
I installed my new cycra handguards & Maxxis Desert IT tires:
then I loaded up & headed for a ride, but on the 405 downhill, the following happened, causing me to swerve on the rim to the side of the freeway:
So I unloaded everything on the side of CAlifornia's busiest freeway & changed the wheel. I never made it to my ride after this:
That sucks.
Steve
Got it washed from my New Years trip. Serviced all the minis for the next trip, and spent the rest of the day figuring out how to straighten my tweaked sub-frame.:lol:
lubed the chain (half the bike lol), cleaned the metal work/exhaust/kicker/frame etc with solvol metal polish, cleaned the plastics (again) and trecked to halfords/partco to pick up some castol 10w 40w oil, chain lube etc. Now twiddling my thumbs waiting for a phone call telling me the rhs engine gasket set has arrived. Big smiles from then on. Oh yeah being a dumb idiot I managed to drop a socket screw bit somewhere near the starter motor. Spent 10 minutes looking for this bit but no luck:banghead: How do you find a needle a needle in a haystack? magnet time.
  • Similar Content
    • By Medard
      So i just rebuild my top end of my 2005 250F, i had 35 houres on my piston and cylinder so i decided to rebuild it.
      it ran perfectly before the rebuild, my timing is right, i have spark, en my sparkplug is a little wet so i have fuel... If i try to kick it it starts to run but after 2seconds it stops running. does anyone know what i have to do?
      thx Medard from belgium
    • By Henry Gooner
      Hey Guys,
      So I am 270# and 6'. I used to ride and want to get back into it. I definitely have a good amount of experience to handle both a 250 and 450 but not sure if a 250 will be able to handle me.
      Right now the bikes I am between are:
      2012 YZ450F @ 50 hours for $4000 CAD and trail ridden https://www.kijiji.ca/v-view-details.html?adId=1302150376&requestSource=b 2012 KX450F @ 35 hours for $3800 CAD and trail ridden https://www.kijiji.ca/v-view-details.html?adId=1300722287&requestSource=b 2010 CRF450R @ 45 hours for $3200 CAD and trail ridden https://www.kijiji.ca/v-view-details.html?adId=1296942462&requestSource=b All these bikes are in really good condition from what I can see from the pictures and none of them raced or track ridden. My plan is to build a 5 acre track in my backyard and build some sort of track along with mainly using it for trail riding.
      I guess what I am asking is for some suggestions and opinions that could help me decide.
    • By short450
      Very nice Rekluse Core EXP 3.0 Clutch that has been ran for about 40 - 50 hours.  The Core EXP 3.0 gives you the best of both worlds as it is fully automatic and allows you to operate it just like you would a manual clutch.  Was getting ready to install in a 2017 YZ250F so I wanted to freshen it up and bought a brand new EXP 3.0 Disc which has never been oiled up or installed.  Before getting time to install the clutch, I decided to sell the bike.  It fits a 2014 - 2018 Yamaha YZ250F.
      ONLY $575 shipped anywhere in the lower U.S.
      Please call or text me at 801-362-8899.
      Thanks!
    • By 27latemodel
      2006 Yamaha WR450 CA street legal, low hrs clean bike, desert tank and stock tank, FMF muffler 3800.00 obo
    • By Jake Gibson
      Hi guys I just did a top end rebuild on my 2004 yz450f and I inspected full motor, replaced the bottom end gaskets and seals, timing chain, cylinder, piston,rings, top end gaskets, valves, spark plug, and it ran fine fr about 15 hours besides a quiet ticking noise. I was put riding the other day and after about 6 hours of riding that day my buddy asked what my rev limiter sounds like and I said i don't know and I don't want to blow it up and he said it won't blow up so I started it up and pinned it to hear the rev limiter and I only held it open for one second and then it backfired and died. I tried to start it back up and the compression is extremely low. I can push kick it over with my hand easily. Pulled the head off and found some very small metal particles on the cams, timing was fine, and the top of the piston is ok, (haven't taken it out of the cylinder yet).... Anyone know what it could be???
