Carb tear down.
Hey all
About to pull my carb apart (first time). Ready to give her a good clean out and check for wear. Is there any tip you all have on this procedure ?
Also I hear a few people talking about reseting Float etc. Will this be necessary and if so how is it done ?
Cheers in advance
Yes, make sure you press super hard on those phillips heads when you take them out, if you slip and grind once, you'll never get it out without grinding a flat head into the screw head.
Replace with metric allen heads, make sure they're long enough and the right pitch. One of mine wasn't long enough and it started to strip out.
Also, pay attention when taking out the slide linkage shaft, it's a little goofy and it took me 30 minutes to get it right again. As for the float height, if it's not spilling over, dont do anything.
It's really easy once you see everything out.
