Please Help! 07 450r Wont Start!
Hi All! My husband and I changed our air filters for the first time last night, I saturated the air filters like they said, but apparently too much b/c they it was leaking a lot out of the bike after we reinstalled it. When he tried to crank it, it cranked for about 1 1/2 secs then backfired, and we can't get it to cranks since! We have taken the air filter out to squeeze out excess but it had already drained all the excess out. What in the world could it be? I know all you smart guys know something! ;)
Please help, as I have no idea what else to do! :excuseme:
Thanks so much!!
Heather
take out the plug and see what it looks like.
Im afraid to ask ... how long did you ride it before changing the filter?
Did you wash the filter? In water? Was it dry before oiling? What kind of oil used?
Thanks for the reply guys! Well... honestly it was too long to change the filter... but we did it straight by the manual, used a air filter spray cleaner, rinsed in warm soapy water, rinsed with water, dried almost completely, there was very little dampness to it, there was too much oil I am sure of that...
about the spark plug, the tool that came with it will not remove it, it is too big for it, it just spins around and around... don't know how to get it out now... we don't have any other tool that could/would work :(
keep the comments coming, they are much needed! thanks!
Heather
If you tried to start the bike and air filter was over oiled you probaly sucked oil into the carb and clogged some orifices and/or jets. I would remove the carb and disassemble it and clean it completely.
When oiling the air filter; saturate it completely; squeeze out all excess; let it completely air dry before installing and staring.
  • Similar Content
    • By GarrettSG
      I need recommendations on Honda dealers with good Mechanics in Western Washington. I am in Puyallup but will drive for peace of mind. I have never had a dealer do major work on any of my dirt bikes. But long story short I am on a 15 CRF450R and it needs the 5th gear recall done. Any and all info is much appreciated!
    • By jakebarritt
      I have a 2005 CRF450R with a Trail Tech fan kit installed. I need a little bit larger tank and would like to know if anyone has an aftermarket tank that fits with the fan kit.
      I dont need a monster 4 gallon, just maybe a 2.4 or 2.7 from IMS would do fine.  I talked with both the tank vendor and Trail Tech and neither could give me any answers.
      Thanks guys.
      Jake
      Minden, NV
    • By NickC18
      So I emailed Factory Connection today to see what spring rate I need for the rear as I’m about 6’2” 220 lbs without gear. I also asked for a baseline front fork PSI to start at. This is what I received:
      Nicholas,
      The spring series we made for your bike is limited when it comes to larger/stiffer rates.
      The spring rate you need is 5.9/6.0 range. We don’t sell that over the counter as it requires special installation process.  So we can’t sell the spring “over the counter”.  It would have to be installed at our shop.
      Fork PSI I would recommend:
      Inner 160 psi
      Outer 11 psi
      Balance 160 psi
      Are they blowing smoke up my ass? What kind of ‘special installation’ could a spring take? I’ve changed and removed them before but not on a 16’ CRF before.
      Also, aren’t those psi settings for the Kawasaki KYB? I don’t think the psf2 have inner/outer/balance do they? Maybe he was having a bad day...or maybe I’m an idiot. FC’s website list there spring as ALS-0059. Can I not just order this spring and install it to set my sag correctly? Help?
    • By johnsbikerepairs
      hi, i have a crf450R 2009, having difficulty setting the idle knob to factory setting.  Having problems interpreting manual Japaneses interpretation.  Can anyone out there assist with the correct factory setting and how i can manually do the setting ie how many clicks out or in etc...   would appreciate any assistance
    • By Baja Designs
      Hello CRF450R Owners,
      Bailey here with Baja Designs.  We recognize ThumperTalk as one of the go-to sources for information on the CRF450R and we receive emails daily regarding the best inexpensive light setup or purchasing the B1K setup ran by Ox Motorsports.  We would like this thread to be a General Discussion area for members and guests to discuss Dual Sport Kits (DSK), Lights, and Lighting Acessories based upon stock and modified charging systems.  Please Post up if you have any questions or comments CRF450R related!
      www.bajadesigns.com
