Interchangable Rims?
I am looking for a second rear wheel that I can put a paddle tire on so I can just do an easy swap at the dunes. Just wondering if any of you guys with more experience with these bikes know what other bikes wheels will bolt right on the the 400? Thanks
There are some KTM wheels that fit. Do a search for just that :thumbsup:
Thank you!
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
