Anyone with Super Moto fender on an S ??
Anyone have pics of an aftermarket supermoto fender on their S? I have the S 21in rims and was wondering if these fenders would be too small. I have the blue S so my options are the Acerbis Teknic or their supermoto. Wondering if anyone has done either. Thanks.
Stock Suzuki BLUE SM fender on an S in Tard mode.
Same deal but with the Adventure/offroad/explore mode.:blah:
Thanks....that is exactly what i am looking for. Stock blue suzuki? I didn't realize SM models come in blue? Where did you buy? This is the fender i want.
Black supermoto fender on my E
Any Canadian Suzuki dealer. $70 Canadian.:thumbsup:
Waza555......What tires do you have on the bike in that pic?
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
