2007 yz250f jetting recommendations
I have a 2007 yz250f. I have modified the bike slightly and i am curious if i need to rejet the carb to get the best performance?????
so far i have done--
power now insert
quick shot acc. pump cover
big gun evo x slip on exaust ( even though i am running the stock header big gun still recommends re jetting the carb?)
removed the backfire screen in the airbox
i am new to the 4 stroke world.... any advice would be much Appreciated.
Thanks
Jordan
Hi, welcome to TT.
Probably yes. The simplest thing to do might be to get a JD jetting kit for your bike and go from there. Get an aftermarket fuelscrew if it's in the budget. I use the GYTR one, but it's a few $ more than non-oem.
Here's a link for setting your pilot circuit. The main and needle are quite a bit easier. The accelerator pump circuit can be a drag.
http://www.thumpertalk.com/forum/showthread.php?t=327405
MJ: ride the bike at WOT. Go larger on the MJ until the bike stutters. Use 1 size smaller MJ than that.
Needle: Select the clip that provides the best control and power between 1/4 and 3/4 throttle.
AP: Tune out any off-idle bog (when riding the bike) by o-ringing your accelerator pump linkage and installing an appropriately sized leak jet.
There are plenty of posts on these subjects. A little searching should be helpful.
  • Similar Content
    • By Nicturner
      Hi fellow thumpers,
      firstly if there is other threads on this topic I apologize.
      i have a 2009 KTM 450 exc. I live at 5500 feet. I have a keihin carb. I currently have it set up with
      green needle (jd kit) @ 4th from the top
      main #175
      pilot #42
       in setting it up for some desert riding I plan on doing next month (LAB2V). Right  now I’m getting a bog if I rack the throttle a few times. I’m reading this is semi normal as the accelerator pump has a hard time refilling.
      i have put a new diaphragm, spring, lean jet is at #40 and air fuel acre 1 and 1/8 out.
      im planning on going back to 172 main, red needle 5th from the top and #45 pilot.
      i normally ride the trails around lake arrowhead and Big bear in California. The trails are single track from 5000-10000 feet.
      Anyone see any issues with either set up?
      how about the big if I get on it a few time ( not really noticeable when riding)
      sorry for the questions. This is my first carb I’ve ever worked on.
      Thanks in advance
    • By SNORE125
      Anyone else have 130 main and 38 pilot jets already in the carb I took the wifes ttr 230 carb apart to add the bigger jets and this bike from 05 that I bought new already had them in it? I was reading that they came with a 125 main and a 36 pilot.
    • By Charles Joseph Miron
      Hello all.  Need a helping hand here..
      I bought an older TT225 and am not about to spend almost $600 on a new carburetor for it. So I'm hoping someone can help me out with an idea of what (other than original carburetor) style, type and brand I should go with..  I'm also having a bit of trouble finding info on this bike.  It's a 1986 Yamaha TT225.
      Thank you in advanced
      Charles
    • By Br0ck
      Hey guys, I went on vacation all summer and let my bike sit (2002 CR250). When I got back I ripped it apart and cleaned carburetor and put it back together and it started fine and ran alright, but idled really high. I adjusted the idle screw and realized it was a ridiculous amount of turns out. I can't remember exactly how many but id say 6+ turns out. My killswitch was a POS and didn't work anymore so I replaced it with an oem replacement. My last ride I crashed the bike pretty bad and I was off the bike for 2 weeks. I can't get the bike to start ever since I got installed the new killswitch. I think I wired it right I just replaced one wire at a time and it looked pretty straight forward. I verified it by testing spark while holding it in I was getting no spark but with it in running position it would spark.
      Anyway I am just looking for some base settings for the Mikuni TMX to get my bike running again, my carburetor has a 35 Pilot and 380 Main jet which appear to be stock. I am located in Edmonton, AB, Canada which is about 2500ft and usually ride between 10-25 celcius.
      Thanks for any replies.
    • By Goon Rides
      Hey guys... so I have a problem... I took the bike at Cal City, broke it in, and while I was doing so, the bike was bogging in first gear (Yes, first gear). Also it doesn't idle at all. I have to keep blipping it otherwise it'll stall. So I adjusted the screw circled in image 1. Well I was listening to the sound of the of the bike, yet the rpm's weren't increasing, and it was still stalling. So then, I unscrewed the screw in image 2, well I found out that it was fully twisted to the right. So then, I twisted it to the left, still nothing; it was still stalling... where's the idle screw? I am sure that the screw in image 1 is for the air/fuel mixture screw, and the screw in image 2 is the idle screw, just broken? I don't know, any and every help would be appreciated.
