Gear lever correct maintenance ?
Sorry, that might sound a little odd but i need some tips about maintaining the gear lever. I already got through 2 levers in just 7 months because the teeth completly wore and the lever couldnt hang on to the shift shaft. now i baught a new one, yamaha geniune off course, and i dont want it to end up like that too.
So, every few rides the lever naturally get a little bit of free play on the shaft, do i just need to tighten the bolt a little bit, or do you suggest replacing it every time? consider that the tighter you put it, it bends a little in his home and in my last lever the bolt just broke inside and i needed to drill it out to get the lever off the shaft!
also, is there any kind of special washer or bolt which is recommanded?
lonzo I believe the failures that you are experiencing are related to your splines becoming damaged and you over tightening the shift lever bolt to compensate hence damaging he shift lever. The most common way the splines become damaged is because the clamp bolt becomes loose. I would strongly suggest that you use a thread lock compound, this should help prevent the bolt form coming loose. Keep an eye on it.
are you banging the shifter hard when you shift...??? are the splines on the shaft wore or damaged..?? when you tighten the bolt..make sure the spline are engaged properly...Its only aluminum...wont put up with too much abuse..
  • Similar Content
    • By fudgypup
      Garrett Poucher and Skyler Howes of Garrett Offroad Racing are headed to Dakar!  These US privateers are headed there for their first times but Skyler is fresh off a victory at last week's Baja Rally, won the Sonora Rally in March and this team placed third in the Baja 1000.
      They have a fundraising link set up and could use your help.
      I raced with Garrett at Baja Rally last year and then both of them at Sonora and was honored to pit with them as well.  They're both super guys and work their assess off.  I think they both have good chances of not only finishing the 11 days of Dakar but placing well.
      They're doing some rally training events this Sat, Oct 20 in Santa Clarita, CA and then another Oct 28th in St. George Utah so if you've ever considered learning rally raid navigation, this is your chance!  It's a lot of fun too.  More info on that at the link.
    • By Big64N
      Good condition with a long list of high end upgrade parts.
      Rekluse EXP 3.0 with cover and slave
      EVO- Ellensburg suspension tuning for 6' 200# expert rider
      Fork bleeders
      Trail-tech map switch
      Moose 1-1/8 flex bar
      CYCRA probend bar guards
      SXS skid plate with linkage plate
      Clutch and water pump guards
      Frame guards
      Fastway Evolution III pegs
      SRT Pro Armor radiator and rear rotor guards
      Acerbic Front rotor guard
      TM designs chain guides
      DID race chain
      Renthal sprockets
      Gripper seat
      FMF F-bomb header
      Dirt Tricks timing chain tensioner
      Pro Wheel, wheels
      Tubliss front and rear
      New top end and valve adjustment 60 hours old
      Many more aftermarket parts as well as spare parts and service manuals included in the sale.  Willing to include 4 sets of tires with 80% tread left for full price.
      Great bike with plenty of life left and set up for anything from single track woods to wide open dessert.
      Can hang with any of the 450's but is much easier to handle in the tight woods.
      Priced to sell at $6000.00
      Willing to consider reasonable offers but no trades or carry.
    • By filterx
      34 Days and what ever in Beautiful Chile
      http://www.fim-isde.com/home/
    • By Project57
      So if I can’t buy a used bike from out state looking for anyone that has or knows of a low mileage California 2017 / 2018 Beta 500 RRS?
      Thanks in advance!
    • By Project57
      Looking to buy a used Beta 2017 500 RRS from outside California.  Can I plate (Register with CA DMV) the bike in CA?  If so what is the best way?  Don't have the money to put down for a new bike from a Dealer in CA.  Any help or sugguestions would be appreciated.  Thanks in advance.
