Which Jet Do I Need To Use??????
I have a drz400sm. It has a K&N filter, 3x3 mod, and I took out the stock spark arrester(I don't know if this makes much of a difference or not). My mechanic has ordered a FMF jet kit for it, & I need to know which jet I sould be using with these mods.
Any help is greatly appreciated.
Thanks, Jeremy
FMF kit is a re[ackaged Dyno Jet kit. Unfortunately, it is not designed for use with a 3X3. You need instead the James Dean kit. You should also get the allen float bowl screws and the Kientech extended fuel screw. The jet kits include instructions for rec. jetting (boith the FMF/Dyno Jet kit and the James Dean)
Not trying to be a dumba** here, but the James Dean kit will have listing for a 3x3 mod in the instructions.
Thanks
the kit you have coming will be fine.it has stg 2 instructions for the air box mod but does not include the 25 pilot jet you will need.
155 main jet
needle clip 2
25 pilot jet
2.75 turns fuel screw
155 main jet
needle clip 2
25 pilot jet
Thank You. I just got done ordering the JD kit and cancelled the FMF, so are the specs you have listed here the same for the JD?
Sorry for my ignorance, I am new at all this.
Yes, all the jets you need are in the JD kit. Good move. Did you also order the allen screws and the extended fuel screw?
Regarding the 3X3, a search here on TT will provide many pictures. Really nothing more than removing the existing inlet snorkle (under the seat). Then, intelligently make the opening 3 inchs by 3 inches (some use a 3" wide putty knife, heated to make it simple). Rejet with the kit and you are done.
I didn't order the allen screws, but I did order the extended fuel screw.
I did the 3x3 mod last night in about 10 minutes. I took my drill and made a hole big enough for a hack saw blade, then finished it with a sanding bit & dremel. Got to LOVE dremels. It didn't turn out bad for a rookie!!
See if you cann add the allen bolts or locate a local supplier,. You will be glad you did, trust me.
I just received my FMF Jet kit yesterday because I am planing on doing the
3x3 airbox mod soon. Th box says it covers 01 through 06 DRZ400S models but I have an 07. Were there any major carb changes from 06 to 07? I am at sea level and plan to do the stock exhaust mod soon also but not right away.
Thank you, I am new to the DRZ world but I used to have a Z400 so I am somewhat frimiler with this engine.
Nope, no changes, you will be fine
I just wanted to thank everybody for their help.:ride:
  • Similar Content
    • By Markl5557
      Anyone’s air box smell like gas ? Is this normal ? Air filter is bone dry but it reeks in there .... I’m assuming cause of the carb being semi filled with gas ??
    • By Markl5557
      So I’m reading these horror stories of the stock vacume operated petcocks failing and letting gas into the oil .... how many of you guys switched over and is it worth it to switch to manual ?
    • By Markl5557
      Hey guys . I feel like I post here way to much lol
      anyway after having my bike kn it’s side overnight to fix a cracked stator cover .... I come to find out that I also accidentally left the pet cock in the prime position .... constant gas flow to carb ... now my oil smells strongly of gas ... my question is ... was it the bike being on its side that made the gas get into the oil or the prime position on petcock that made this happen ? Or both ? I didn’t ride it much at all after discovering... I assume. I should drain the oil obviously but any other suggestions ? Always appreciated -mark
    • By Praneeth143
      Hello guys , I have a suzuki drz400sm which is a 2009 model recently I purchased a rear sprocket which was a JT 41T , but I found that it did not fit to the rear sprocket hub of the bike and my drz has got the EXCEL TAKASAGO rims in it . How can I find one that fits and what sprocket brands and where can I buy it . I have attached pics of the current setup , please help me
    • By Surfman1
      Hello all, first time poster. Just bought this bike a few days ago it’s an 08 drz 400sm and am starting to notice it has a strange backfire at idle. I understand a little bit at decel might be normal, but at idle too?  It appears to have been jetted already, judging by the fact it has a jd jetting sticker on the bike itself. I know that it’s not an exact indicator it has but it could be. Has an FMF exhaust, it looks like a full system rather then a slip on but not entirely sure. A buddy recommended I mess with the air and fuel screw, haven’t done that yet. Just wanted to see if there was any other tips I should try.
