Water Pump Part Mystery
Riding last weekend I discovered large amounts of fluid leaking from the water pump area. I suspected a gasket or something, but instead I discovered a tiny hole underneath the waterpump, but on the crankcase side.
I was shure it was a bolt that had fallen off. Probably the draining plug I thought...
Back home I tried to find the part in the Yamaha OEM parts catalogue. This should list every part on the bike down to the washer. Right?
But to my sursprise I could not find the part in the catalogue.
I've been trying to fit an M4, M5 & an M6 bolt but it won't fit. M4 seems to be the closest, but it is to small.
Does anybody know what this hole is all about? And why is this part a non existing part if I look an the Yamaha spare parts catalougue? I own a 99' 250.
An overview of the water pump: http://www.cmsnl.com/yamaha-yz250l1-1999_model10775/partslist/A-09.html
Thanks.
/Magnus
thats a weep hole to let you know when your seals around the water pump are bad. if coolant comes out its the seal for the water pump side and if its oil its the seal towards the crankcase side. DONT try to put a bolt in there the hole is there to tell you when you have to replace a seal. sounds like you need to get your water pump seal replaced now. its an easy repair
go here and put your yeam and make in and check out the microfiche and youll see the seals i looked at a 06 model under the water pump and it shows a pic couldnt get it on here but heres the link, looked at that link and its the same as the one i saw #4 is your waterpump seal and #5 is the oil seal. if thats your model then you need to replace seal #4
Thank you very much for pointing me in the right direction! A couple of hours
of work and the problem is solved. The Yamaha Dealer even had the oil seal on the shelf. Talk about lucky. Looks like I'll be riding tomorrow after all!:ride:
  • Similar Content
    • By faizakhtar125
      Hey guys I just wanted to show off my bike and show it to the world lol  What is your opinion on it. God or bad, please be honest. I am open to all comments and suggestions. Any upgrades I should do to make it look better and/or faster?
    • By Allooushh
      I bought a YZ250F yesterday and the previous owner said apparently it runs but they weren’t strong enough to kick it. I couldn’t kick while there so I took their word for it and bought it. I’ve been trying to get it to fire all day today, there are 2 chokes and I’m unsure if the air mixture is correct, so would be nice to know what I should do, it’s hard to adjust the air screw when the bike won’t even run. I noticed the spark is kinda low, I don’t know if it’s normally supposed to be like that or not. I can see a blue spark but it is very small and crappy, I’ve had thumpstars that generated stronger spark, I changed the plug it’s still the same, so maybe could be an electrical problem, the only ground connection I could find was for the ignition lead which I filed down to bare metal so I’m pretty sure that connection is good. Anything else I’m missing? It’s very hard to kick and I can feel the compression out of the exhaust so I don’t think compression is the issue.Just wanna know what I should do, haven’t owned a yz before so I could be not using the choke right or something. Thanks
