CR125, YZ125, KTM125, RM125 or KX125
Which bike produces the most power, has the best handling, has the shortest seat height, and weighs the least? Basically, which is the best for a 5'4 140lbs male rider?
Hands down any '99 or newer YZ125 is the bike you want. DONT even bother with the others unless you can get one for unbelievably cheap.
YZ, no questions asked.
YZ 125 is the best 125 made/
KTM
Great motors,lower seat heights, and they come from the factory with better parts (aftermarket) installed. The others may handle a little better, but unless you're an expert rider that can ride it to its potential you won't know the difference.
I say go for an RM125 (01+), KX125 (03-05 were really good bikes and had really good suspension), YZ125 (01 or newer because of the bigger carb, but the other years were good also), or a CR125 (96 or 97 only). All 125's are good from 2001 on except the CR. Go try them out and then buy which one you liked best.
steer clear of the honda and kawi, the 03 and newer i beilieve where redesigned but still not worth it, suzuki and ktm are alright but ktms seem to be going for more than they are worth and suzukis are not as fast as the yamis i would definitly go for the yamaha, they always turn up at good prices, especially the 97-04s good luck
I would steer clear of any KX. Every one of their bikes has rated dead last, or second to last in every magazine test for years. Not much devopment or innovation in either the 125 or the 250 for quite some time. There are much better bikes available for the money.
Yamaha makes the best tiddler out there and they are reliable too. Trust me on this. :prof:
Yea what he said.
Ktm...
Probably due to them not paying any of the mags as much as the other companies are......
Mag's report as much factual information as they do opinion. Technical specs are technical specs. The frame geometry and suspensions are junk, and have been junk on KX 2 strokes for years. The motors on paper may make as much HP as the other bikes, but always have some odd hit to them, or make power in such a way that they are unusable to anybody less than a pro. The bottom line is that you can get much better for your money.
yz is the tallest tho. its 39" seat height and i know the kx rm and cr are 37" seat height. i have the same problem as you as im also short at 5'5" but i weigh only 115 pounds.
i am a honda but i have to say yamaha nailed the 125 this year for ll around performance
  • Similar Content
    • By Yamaha0963
      So I started my bike today and a lot of smoke came out from where the air boots  clamp on the carb (both sides) where the air boot meets the air box, and where the pipe meets the cylinder. I can also hear a leak but I am not sure from where. It also bogs. What could this be??! I started it yesterday and it ran fine, no leaks, no smoking, bike revved up good and everything.
      i should point out that I did take the carb off, disconnected the air boot from the air box. I put some grease on the air boot so it would seal against the air box when I put it back together, it was a pain in the a$$ installing the carb but I made sure that the air boots clamp all around the carburetor. After I was done I started it and it was completely fine, no issues.
      UPDATE:
      well it turns out that I still had the exhaust plug....(Facepalm) should I be concerned that the air found a way out??? If air can find a way out then air with dust can find a way in. Also, could this mean bad reed valves?? It has the vforce reeds but the cage is grey with purple lettering (not the normal black cage with yellow lettering)
      thanks
    • By Yamaha0963
      Hey so I have a Cr250r with a few mods
      -PC pipe
      -Vforce reeds
      -Keihin PWK carb
      I was wondering what race gas I should use, I am a weekend rider and I do not race or anything like that, I just want to use some race gas on my bike so it runs better. (Don't want to run straight up pump gas)   I am looking to mix with 93 pump gas because running straight up race gas is too expensive for me.  What gas would be good for me that is not too expensive. Thanks!
    • By Yamaha0963
      Hey guys, so I recently bought a 02 cr250r on Craigslist.  The guy claims it has a new oem cylinder and piston with 30hrs and a new crank with 60hrs.  The bike also has a PC pipe, vforce reeds, keihin pwk.
      Now my question is are they so easy to start?! My last bike was a yz250f and it had quite a bit of resistance when going through the compression kick and I got used to it.  When I went to start the cr250 I went through the compression kick out of habit and notice that the kick starter would drop under the wait of my leg and it was awkward for me as I was used to starting a 4t.  The bike started first kick cold with choke on and after warming it up it still started first kick.  Is it normal for the kick starter to drop under the weight of my leg or does it have low compression? Like I said it start first kick very easily.  The guy had 50/50 race gas and 93 pump gas at 40:1 (don't know about the premix) in the tank but I will be running 93 pump gas with stabil at 40:1 with Maxima super M (can't afford race gas) when I need to refill.  I will update when I start running my gas and see if it still starts the same. Thanks!
    • By Roman Krzyzanowski
      I have a 2000 Cr125r and I’m in the middle of rebuilding it I just put a new crank and new bearings and all new gaskets so far. I haven’t made it to the top end honestly I’m kinda stuck at this point I &%$#@!ed up and didn’t take pictures while taking it apart mistake on my end because I can’t even find any pictures or anything on it now. I already put the cases back together I’m now on the shift brake pause side I was wondering if anyone could help me with a few pictures of that side of the motor if someone had some? Or send me a link of a diagram of how it’s supposed to be and look. this is the only part I’m stuck on it’s pretty tricky but after that i just got the top end I really appreciate any advice or any pictures y’all come up with or diagram EVERYTHING helps I’m kinda dead in the water at this point ..
    • By 870
      I have a 2005 cr125 new to me. I had millennium tech replate cylinder and supply new piston. I replaced crank bearings and now it won't hit power ban. It feels like a 4 stroke bouncing off rev limiter. It is also putting a lot of black spooge out of exhaust i mean a lot. The plug is black. I cleaned carb and adjusted floats. I also repacked silencer. I noticed the carb leaking gas out overflow the other day. I suspect it is running really rich. I have a brand new pwk from Jd jetting I'm going to try out. I also did a leakdown test and it held. I also am not 100% sure the power valve is set up right. The manual doesn't go into great detail about this. But it seems like there is only one way to put it back together. I have the engine out I'm going to do another leakdown test and double check my power valve and put it back together with this pwk. Any other thoughts out there?
