Antigravity Batteries Product Giveaways - LAST NIGHT TO ENTER! Read more... ×
Do I Need a New Cylinder?? Picture Added
Yesterday I pulled the top end on my 02 crf450. The gentleman I bought it from had already had kibblewhite valves and springs installed as well as a stock 04 piston and cam chain tensioner about 50 hours ago. I have checked the valves every 10 hours for the 30 hours I have owned it and they have not moved from .004/.010. I pulled the thing apart because I thought it would be time to replace the rings and possibly the piston and wanted to go with a high compression piston. The piston looks good and shows no signs of blowby.
But the cylinder has two gouges on the exhaust side where the piston skirt contacts the wall. These can easily be felt with a fingernail and it also feels as there is a low spot in between them. The crosshatch on the bore looks good. I do not have an inside mic to check for and out of round condition.
Should I replace the cylinder?
What is the break in and installation for a new cylinder? Does it come ready to assemble out of the box? Or does it need to be honed?
And lastly where would be the best(cheapest) place to get a new cylinder, JE hi-comp piston, and a gasket kit?
Sorry for the long post, but I wanted to be as detailed as possible:blah:
Thanks
Unless your compression is low, and or the bike does not seem to be running right, then you could replace the cylinder. I found very cheap price for a new cylender here: http://cgi.ebay.com/ebaymotors/New-2002-CRF450R-Cylinder-02-CRF450-12100-MEB-670_W0QQcmdZViewItemQQcategoryZ35595QQihZ011QQitemZ320089956994QQtcZphoto
The bike ran perfect when I tore it down. I just want to put in a high compression piston because the piston is at about 50 hours. I want to address the cylinder now as well because of the gouges. Does a new out of the box cylinder need any prep before assembly?
A suggestion would be to buy an Athena kit since you are looking for more grunt.
Not a bad deal at $734.95 when considering the cylinder, piston, gasket kit and HP too! Gets a five star rating from MXA.
should have left it alone till it started running bad. I have close to 150 hours on mine with no problems at all. especially since the valves havent moved. just my .02
Yeah I'm not really trying to spend that much. I can get the 02 cylinder, a JE piston kit and a gasket set for like 375.
I am going to get a picture of the clyinder. The indentation I am speaking of is more of a dent than a gouge, no rough edeges at all, right where the piston skirt is on the exhaust side at TDC.
I would replace it.
The new cylinder will be ready to go on. Just clean it out real well with ATF and a white paper towel, then contact cleaner till it comes out clean.
garage.php?do=viewattachment&attachmentid=45954
Picture of the section of cylinder wall that is in question...
This is the exhaust side and the two gouges created by the piston skirt can easily be felt with a finger and fingernail.
It might come out with a hone.
Not unless it was a diamond hone. If he can feel the mark with a finger nail its significant. He's got nothing to loose by running a hone down in there and trying though.
Something else comes to mind here though...its an 02, thats had the top end rebuilt once already. The bottom end of the thing needs attetion, you can bet your ass on it. Id be hard pressed to correct the top end at this point and forget it. Unless he just wanted to off the aging bike... :excuseme:
I went ahead and just ordered a new jug this morning. The two dent/gouges are fairly significant and I doubt they would come out with a dingleball hone.
This is my first crf, what are the common bottom end problems?
You will want a new crank if it has over 200 hours.
Cam - can you explain why? Is it because they got out of round? Do they break do to the 11000rpm style motor?
I trailride my CRF but would imagine crank replacement as a massive job?
If the bike has seen nothing but trail riding, you can go longer on the crank. An advanced MX'er would want to replace the crank at 200 hours because the small end of the rod galls the big end goes out of round and the main bearings are often starting to brinell.
  • Similar Content
    • By 33KTM350
      I just bought a Magura hydraulic clutch for my 2014 CRF450R.  Bought it thinking install would be easy, and I'm not sure that's the case now that I have the product in my hands.  I have searched the forums, YouTube, etc for install help specifically for my model year (2013 and 2014 are same really), and haven't found anything specific for the 2013-2014 model install at all.  Instructions from Magura are TERRIBLE, and are not specific at all to the Honda - generic instructions - so I'm debating if I want to return the product, cuz I don't want trouble or a big install job.  Question: for the 2013-2014 CRF450R install ONLY of a Magura Hymec hydraulic clutch - other model years are different and thus it won't be helpful for other model years - do you have any tips or feedback?  My concerns are below...
      1.  The 2014 model has a sleeve behind the clutch actuation arm that the Magura clutch slave cylinder fits into.  Stock, the sleeve holds one end of the cable, with a nut on the other end to keep the cable end tight in the sleeve.  The Magura slave cylinder, however, slides into the mounting sleeve  - but does NOT have a nut: the tension from the clutch actuation arm pulling on the metal Magura slave cyl tip end is apparently supposed to keep the Magura slave cylinder tight in the mounting sleeve.  Q: Will the Magura slave fit in to the mounting sleeve easily, stay tight, and is there any adjustment needed in order to keep the 4-6mm of freeplay that Magura recommends?  How easy is it to get the Magura slave fitted into the sleeve and the metal tip in place?  Is there enough freeplay between slave and tip end to mount in actuating arm AND the holding sleeve, so that the holding sleeve doesn't need to be unbolted?
      2. The stock clutch cable and OEM setup runs out of the mounting sleeve (see pics marked "metal starts", and then runs through a metal sleeve that routes the cable through the engine compartment - keeping the cable away from the hot parts of the engine case, so as not to melt the cable insulation (I believe).  That metal sleeve is about 6-8 inches in length.  The Magura clutch cable, on the other hand, exits the Magura slave cylinder at an angle - yet has no such metal routing.  I don't think the OEM metal routing sleeve will accept the Magura cable either, so a) the OEM metal routing sleeve would have to be removed first before installing the Magura - and then b) you have to hope that the Magura cable can be routed in such a way with zip ties holding the hydraulic line that line will not touch or be close to the hot metal engine casing as you route it through the engine.  Q: how easy was it to get the OEM clutch cable and metal routing sleeve out?  Easy as unscrewing the nut on the other end of the OEM cable, on the other side of the black rubber cable flange in my pics?
      3.  My stock clutch pull isn't bad.  I just like the feel of a hydro clutch.  Any feedback on how much better feeling and easier pull will be with the Magura?  What's your feedback on the difference?  FYI, I'm leaving my clutch plates and springs stock.
    • By Eric Blasiman
      We have a 2016 CRF450R with about 11 hours out. never ridden hard always check the oil and change when needed along with the air filter. Took care of the recall that was required as well. Well when riding the bike was stalled out. Went to try and kick start the bike again. the kick start lever just back up jamming my knee into the handle bars and some how ended up cracking the case right by where the kick start goes through the case. Has any one had this happen or heard of this happening? What is the cause?
    • By crfjunky1320
      Any advice on what should be replaced while I have the top end off for a valve replacement. Will do headgasket and springs of course, anything other parts you would recommend while I'm going at it?
      Thanks!
    • By Ron Whitfeld
      The dirtbike is on it's forth year right now on the same motor job. I have to jump start it. Is it worth me trading for a 2009 650 brute force with7000 miles? Need some expert advice. Thanks
    • By Lucas Hansen
      Just wondering what you guys do to remove black marks on your seat. My 08 crf450r has the red/black seat, and after each ride there are some black marks on the red from my riding pants. Not scuff marks, more like patches of black residue from my pants rubbing on the seat. I’ve tried the magic eraser which seemed to do the trick, but lately they seem like they aren’t coming off. Also tried scrubbing bubbles with a brush and no luck. Not too worried cuz I have an spare OEM seat, but I’d like to keep this one nice. Any ideas? Maybe I shouldn’t wear black pants?
