Take a look at this lovelyness
Pretty huh?
Can you say rebuild?
The jug looks good though, right? There is no scoring or signs of blowby. I can't feel any lower end rod or crank play but there is some in the upper end. How can I know if the play is the rod, pin or piston without a guage?
Thanks for the show and tell
very cute. time for high comp setup.. maybe stroker kit! :D In my dreams eh.
depending on the hrs on the bike I wouldn't worry about measuring the cylinder... It looked fine to me, but it wouldn't hurt.
From the pictures everything looks to be fine, but why is there so much carbon on the piston? Is it running a bit rich, or is that just the pump gas?
As for the play, you shouldn't be able to move the piston up and down when it is attached to the con rod. If you can, I would measure out the ID of the upper con rod and make sure it is within spec.
What about the valve train... If the valves haven't moved, you could just leave it alone, but if it were me, I would take it apart to clean/inspect everything...
And yes, its time for that J&E High comp piston kit :thumbsup:, TT store has them for around $150.........But a stocker/OEM one will do perfectly fine :ride:
My intakes zeroed out and there was some grime in my carb. So either bad pump gas (which I run premium) or my KnN air filter had something to do with it. There is some left to right on the lower end of the rod but it should do that, right?
if you push the rod left and right, it should have play...
As for the K&N filter, yes they are known to let dirt/dust through, that is the one of the reason why your intakes zeroed... I would huck the K&N in the trash and pick up a twin air airfilter and some Belray or Maxima FFT foam filter oil...
For the cylinder head, I would send it out to get the seats cut and new valve guides installed... For the intake valves, I would pick up the faction MX intake valve kit, it comes with Stainless steel valves with a Black nitride coating, springs, retainers and cotters. So basically everything you need for the intake side of the head. The kit is around $165 ish...
You will need to pick up new OEM guides (4) and seals (4)...
For the exhaust side I would pick up some new OEM exhaust valves (2), springs (2), retainers (2) and cotters (2 sets)...
Don't forget about getting new cylinder head and cylinder gaskets also...
:ride:
I checked the clearance between the lower end and crank and its over spec so I guess now Hot Rods here I come. I couldn't feel play in the crankbearings but there is play on the counter balance shaft. I'm guessing that's not good. The shaft didn't look like it had wear or galling so could it be the bearings or is some play there normal? I wouldn't think so but I'll have to read the manual.
Here's what I wrought today
I hate removing old gaskets
Not so bad for a first timer. Well at least i got it all apart. Waiting on crank, bearings, seals, piston, head work and then will reassemble. I guess then we'll see how I did
  • Similar Content
    • By jakebarritt
      I have a 2005 CRF450R with a Trail Tech fan kit installed. I need a little bit larger tank and would like to know if anyone has an aftermarket tank that fits with the fan kit.
      I dont need a monster 4 gallon, just maybe a 2.4 or 2.7 from IMS would do fine.  I talked with both the tank vendor and Trail Tech and neither could give me any answers.
      Thanks guys.
      Jake
      Minden, NV
    • By smythe
      Complete 2009 CRF 450r cylinder head with valvetrain.
    • By NickC18
      So I emailed Factory Connection today to see what spring rate I need for the rear as I’m about 6’2” 220 lbs without gear. I also asked for a baseline front fork PSI to start at. This is what I received:
      Nicholas,
      The spring series we made for your bike is limited when it comes to larger/stiffer rates.
      The spring rate you need is 5.9/6.0 range. We don’t sell that over the counter as it requires special installation process.  So we can’t sell the spring “over the counter”.  It would have to be installed at our shop.
      Fork PSI I would recommend:
      Inner 160 psi
      Outer 11 psi
      Balance 160 psi
      Are they blowing smoke up my ass? What kind of ‘special installation’ could a spring take? I’ve changed and removed them before but not on a 16’ CRF before.
      Also, aren’t those psi settings for the Kawasaki KYB? I don’t think the psf2 have inner/outer/balance do they? Maybe he was having a bad day...or maybe I’m an idiot. FC’s website list there spring as ALS-0059. Can I not just order this spring and install it to set my sag correctly? Help?
    • By johnsbikerepairs
      hi, i have a crf450R 2009, having difficulty setting the idle knob to factory setting.  Having problems interpreting manual Japaneses interpretation.  Can anyone out there assist with the correct factory setting and how i can manually do the setting ie how many clicks out or in etc...   would appreciate any assistance
    • By Baja Designs
      Hello CRF450R Owners,
      Bailey here with Baja Designs.  We recognize ThumperTalk as one of the go-to sources for information on the CRF450R and we receive emails daily regarding the best inexpensive light setup or purchasing the B1K setup ran by Ox Motorsports.  We would like this thread to be a General Discussion area for members and guests to discuss Dual Sport Kits (DSK), Lights, and Lighting Acessories based upon stock and modified charging systems.  Please Post up if you have any questions or comments CRF450R related!
      www.bajadesigns.com
