04 ktm 250 exc rfs
Bike ktm 250 exc rfs 2004 mods: t4 pro circuit pipe
carb pilot jet 45, main 140 needle 2 from top
problem runs ok I live at about 10000 feet around 12000 feet the bike sounds really deep. From a stop I will go about 10 feet and it will die. ( sounds like it is bogging dow,
I rejetted to same needle clip postion pilot jet 40 main jet 132. Now when I give it gas from a stopped position it dies at any altitude I hace to slowly work the throttle to get it going. To me I think it is to lean now.
Do you have any recomendations on what to change? either pilot or main or needle clip.
as always your advice is greatly appreciated
thanks!
sounds like the needle is to lean.
I will give it a try
thanks
  • Similar Content
    • By whiteduke13
      Bought a 1999 Yamaha xt350 couple months ago from a guy that hadn't started it since 2011. I started off removing majority of the big chucks of rust from the tank via bolts/vinegar, and replaced the fuel line, and inline filter with a see through material. Additionally I had the carburetor cleaned by a local shop. The shop messed something up and now the choke is stuck in the closed position, but the bike ran fine for two days in a row (about 2 hours each day). A week later it started dying while riding and I believe its because fuel isn't making it to the carb. I've checked the screens on the petcock, and replaced the tubing and filter to the carb. Before having the carb cleaned the inline filter would completely fill up before starting the bike but now only fills to a third of the way. The inline filter goes dry when running thus the motion fuel isn't making it to the carb. Flow through the fuel line is at a trickle when connected to carb but gushes when fed to a gas can. Any ideas to why I'm not getting flow???
    • By Kawasuzuki456
      So I have an 03 rm 125 and I’m having a problem with my jetting. My original 460 main jet that came out of the carb is huge and unlike any jet I’ve seen before. I also ordered a mikuni genuine main jet off of eBay and went to go put it in the carb (440 main) and it’s way too small. Not sure what to do.
    • By AKrazy
      Hello kids,
      Looking to get my second dual sport. Ive been riding for 3 years on my DR200. I mostly prefer single track and technical riding.
      I recently test rode the DRZ on dirt. I liked the extra grunt, but found it too tall for my legs and too top heavy for my riding style.
      Anyway, I like what I've read about the KLX250's suspension and aftermarket mods. I see "easy install" kits and directions all over, but no information as to how the 2018 kid's EFI will change installing these kits.
      Will it require an aftermarket EFI? Or possibly even a carb swap kit?
