motor swap
i have a1983 xr200r motor blew are there any other motor options out the that will fit in this bike 200 250 350 mabe a 400 thanks dont know much about his bike just got it thanks james
any 86 and on 2 valve motor should work fine. i blew up my 82 xr200r and i am using engine parts from a 1990 to create one working engine to use in the 1990 frame
will an 86 motor bolt right up?
Be careful, after 83 they went to the twin carb RFVC's for 84/85, these will not fit an 83 frame. Also later on (maybe it was from 86 onwards) they switched back to the single carb motor but changed to a different frame layout to the pre 84 bikes, although the 80-83 motors are more or less identical to the 86 and on single carb motors internally the outer castings are a little different in some areas and I'm not sure that they bolt straight up to the 83 and earlier frames. I'm not sure of the exact details of this but it would pay to find out....................
Post this in the 200 forum, Someone on here will know.................
  • Similar Content
    • By libsead
      Guy's,  I have an 1997 Honda XR400R and I need to do the front forks.  I'm a big guy 6'4" 375lbs.  So far I haven't been able to find a setup for a big guy. Any suggestions besides losing a lot of weight. :-)
    • By Scat Adams
      OEM Rear fender from an XR400. Fender includes Baja Design tail light as well.
      $20 plus shipping, located in San Diego.
    • By Alex John Blanch
      Went riding on Christmas Eve  everything was working fine went through some mud and slipped dropped my bike tried to kick start it and the kick start went limp pushed it back up got compression again  kicked it over a bunch of times started to run again  rode it for the rest of the ride with no problems then on the way back on the road I gave it fill throttle  and it died hasn't started  since and now has little compression. Replaced the spark plug and changed the oil and filter and adjusted the valves but still very little Compression and won't start.
      Any ideas??  Would greatly appreciate
    • By Ricky Bobby 21074
      I have a 1986 xr250r, I'm interested in converting the rear drum brake wheel assembly to a rear disc brake system. Has anyone done this, and can you tell me what application parts will get the job done. thanks
