Check it out Tag Works Triple Clamps & New DRZ400 Head on the Cheap
Just wanted to share my joy with my TT Bro's, I scored these Items off Ebay:applause: I just got them today in UPS
I think they are Tag Works Triple clamps with a 18-21 mm offset not sure they were on a 06 RM250 with 49mm USD Showa Works Forks
NEW DRZ Head:thumbsup:
if anybody knows any info on these Items please fill us in Thanks for looking
by the way these Items are NOT for Sale!
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
