Vintage parts
gonna call ya when I got some frree time on your project. I hear ya on the 4 stroke whing though....gets old....valid points but it does get old.
Joe
Joe - check out post # 18 for the new ITC decals.... website is down but e-mail works ... should not be to expensive over the Atlantic.....
Give me a call sometime when you have a chance to give me some 411 on the 40mm's
T
Here is the reccomended jetting for the 1980 250/390 CR from ProCircuit for Southern California elevation 0 to 3000 ft
Pro Circuit knew Huskys back in the day information is a direct quote from ProCircuit
250 CR Husky 1980
38 mm Mikuni Round slide
Stock Needle 6DH3 change to 6F15
Stock Main jet 430 change to 480
Stock R2 Needle Jet change to R0 or Q8
Go to a 60 Pilot
These changes from the stock factory bike will result in cleaning up the bottom end and make the top end a lot fatter.
390 CR Husky 1980
38mm Mikuni Round Slide
all the same changes but go with a 50 Pilot
Also recomended:
Throw away the stock Husky air boot clamps and replace with standard hose clamps
Seal the air boot to the air box with Silicone Sealeant
T
Grubin & Company specializes in older bikes 60's and 70's (all brands including Husky ) I have heard from other Husky owners that he is one of the premier motor rebuilders in the Pacific Northwest.
Specializes in rebuilding , race performance, porting , vintage parts etc..
Yakima, Washington Cool website
www.grubinandcompany.com/page/page/3817400.htm
T
Several people have reccomended the following for spray can silver on Husky Frames
Rust-oleum Appliance Epoxy "Stainless Steel" #7887 as the closest match to the original Husky frame color
Fast drying and cures out hard and tough.
Duplicolor Aluminum Engine Enamel # EDE1516
Duplicolor Silver #T229
Again this is if you are using spray cans....
T
www.vintageiron.com
here is an ebay link to one of their '81 / '82 pipes
http://cgi.ebay.com/ebaymotors/1981-1982-HUSQVARNA-CR-250-RETRO-ROCKET-PIPE_W0QQcmdZViewItemQQ_trksidZp1638Q2em118QQcategoryZ35581QQihZ001QQitemZ110206779582QQrdZ1QQsspagenameZWD1V
Here is their text:
A VINTAGE IRON Retro Rocket pipe is just what you need to make your Husky throw rocks on the Japanese bikes..
Pulls stronger and pulls longer than any Husky pipe on the market just ask our test rider Bengt N. Battered. Make your Swedish girl happy. Buy her the pipe she always wanted, please! The bike pictured is our '81/82 430 fitted with our Retro Rocket pipe. The 250 pipe looks very similar on the bike. We also make a pipe for the '74 250 Mag, the '75 360 and '77-79 390 Husky. 714. 694-0066/www.vintageiron.com if you have any questions
Select a pict
T
Ok - the name says Maico Only...... I have heard though through reputable sources that he rebuilds Husky motors as well and builds custom expansion chambers, silencers etc.... He also does a lot of performance mods and pipes for older Yammies, Maico's and Husky's.
If this is wrong someone can correct me.....
www.Maicoonly.com
Rancho Cucamonga , California
T
  • 3 weeks later...
Ron Bishop of Ron Bishop Motorcycles in Escondido, Ca. rebuilt my 75 Husky 400WR engine a few years back. Did a good job.:banghead: Steny
Steny :D :D :D:prof: - can you post up contact information for Ron Bishop so that others viewing this thread will have immediate access to a good SoCal engine rebuilder? Any thoughts and specifics on your engine rebuild?
webaddress
email
Contact #
Best contact person
Physical address
I want to get as much information into this thread as possible for any TT'rs looking to work on vintage Husky!
And Thanks for posting :busted: :busted: :busted: :busted: :busted: :busted: :ride::D
T
For those who don't know the parts differences between 1977 ,'78 and '79 vs. the newer style 1980 here it is in picture detail
the 1980 swingarm was basically 1" longer ( Titanium finish swingarm) 23 1/4" and gave the Husky a longer wheelbase ... it tracked very well / was more stable with this swingarm
here is a close up
The shock mounts while all on the top of the swingarm tube did not get strength gussets until 1980
The chain friction guide was short and was only on the top with two screws only as shown
Here are the screws that were used ( these need refinishing) common to any of these years
The 1980 swingarm used a much longer chain friction guide that wrapped the swingarm top and bottom and fastened with four screws and washers ( two top/two bottom this picture also shows the stock Husky chain tensioner bushing in the cross tube. A bolt goes through this to hold the chain tensioner wheel. A better aftermarket option is to remove this bushing and replace it with a greasable zerk fitting as made by Uptite Racing in Santa Ana - please view last picture . George still makes these . Call him for pricing.
Greasable zerk pic
Hope this helps someone understand the different parts difference in swingarms . The 1980 was a very popular conversion for guys running the 78's and 79's.
T
  • 2 weeks later...
