Not exactly the CC's
I've often wondered why companies over-exaggerate the dirtbike's cc count, like giving dirtbikes 449 cc's, and not 450 exactly, and how some companies do this more than others. For example: Honda's crf230f's, only have 223 cc's, KTM's new 530 which only has 510 cc's. Why doesn't KTM call it the 510? Am I missing something here? I don't get it, can somebody shed some light on this subject? :excuseme:
Yea i've been wondering that also :excuseme:
i think its b/c its sounds better. like the crf100 has 99.9cc
But some do it more than other's, the worst is KTM, they're new 505 really only has 477 cc's, that seems like alot to screw somebody out of, I'm one who does their homework before I buy a bike, but I think that it's a little dishonest IMO.
I really dont get it with KTM (and i really like KTM). funny thing is, while they call a 477 and a 510 and 505 and a 530, they also have the KTM 990 super duke which is actually 990...... why not round up like your other bikes and call it a 1000? but i dont find 449 that big a deal. there must be a reason tho because motors are NEVER even numbers. from what ive seen every bike is 449, 599, 999 so on.
the worst ive seen is the Polaris 800 ATV. it's really 760.
1. Market research shows that certain numbers sell better: like a item priced 19.97 sells better than one marked 19.96 for example. 450 sounds better than 449.
2. In the old days everybody would re-bore and piston thier bikes when they wore out. If the motor was actually 450cc stock, and you overbored it to make it new again, technically you would no longer be able to compete in the 450 class anymore.
3. Because it is just a model number.
bore x stroke calculations :prof: ...the manufacturers find a performing,balanced # of cc's that are an outcome of bore x stroke sizes and then pick the nearest # that sounds good
say the bore is a certain mm and the stroke a certain mm, they multiply those sizes and the outcome is rounded, for example a 449 outcome is called a 450 because it will sound better and sell better
how many of you would prefer 450's be called 449's and 250's be called 249's?
Part of that also is that not ALL the cylinders are the EXACT same size. Some bikes (i know for the 2 strokes atleast) when you are going to buy an OEM piston you have to match it with your cylinder. Usually they are marked A, B, C, or D (or whatever that company chooses to use for their markings). Those size differences are like .0001 difference but im sure that comes into play. The bikes technically have to be exactly 250cc or lower for a 250cc two stroke to race in the 250 class for example. And like what was said before, people used to bore their bikes slightly over once the topend was worn out.
Well, when they do a bore and stroke, they get it close. To figure displacement, go .7854XboreXboreXstroke. Then X number of cylinders. Usually, a bore will be like 95mm stroke will be 63.4mm (WR450F numbers) which is 449394.099cubic millimeters. Move the decimal point over 3 places to get 449.4 cubic centimeters, rounded off or rounded to the whole number is 449cc. I suppose they need to get as close to 450 without going over, they can be under, but give up some displacement. I dont think they want bore sizes like 95.1245 etc. I suppose they could add to the stroke by .1, (63.5, up .1 from 63.4mm) but in this case, the displacement would be 469 which would put it well over.
As for the KTM 510, not sure. I know the KDX220 is actually 216. I suppose they just round to the nearest whole number in multiples of 5. That wouldnt explain the CRF230 being only 223 cc:excuseme: Maybe they should of called it the CRF225, but then Yamaha has the 230...
Another example of this is my 05' honda crf150f. It is actually 156cc while the 06 and up 150's are 149.
My 74' Honda CT70 is 72cc (soon to be 85cc) :applause: and my KX100 is damn near 100cc.
But Yamaha did make the 426.. and that actually sounds pretty sweet.
I've always wondered this too
Another example of one that's fairly far off is Husky's current SM610 and TE610. They're 576cc.
The ktm 530 keeps on climbing with the name. I think it used to be a 510.
My CR85 is 85cc's and the Yz is 84.7cc's or something
Cool.... I have a CT70 that's a 142cc
But another thing is, when a company does say the bike has exactly 449 cc's, why can't they just add more on to make it an even 450? I know it won't make a difference, but I just don't understand. :excuseme:
It's mostly marketing. Some words and some numbers "sell" better.
Think of how many times you see the sexy letters like "X" used in products.
Now think of how many products come with a plain Jane letter like "J" or "L"
Ditto on numbers. Six and nine are sexy; 2 and 3 aren't.
the model number is not only an identification of CC size but its a name, a name that they want to be easy to remember, easy to stay, an overall attractive name.. so they market them as best they can
I'm not arguing the fact that some names sound better, because they do. But I'm saying that for example, KTM's 530, should either change their number to 510, or bump up the cc count a little bit, only because it's a little deceiving. (I use KTM so much because they seem to do it the most.) :ride:
  • Similar Content
    • By Bryan Bosch
      Rockstar Energy Husqvarna Factory Racing Star battles Through All-New Format Hell’s Gate to Finish Second
      February 11, 2018 – (Motor Sports Newswire) – Rockstar Energy Husqvarna Factory Racing’s Graham Jarvis has earned a strong second place at the 2018 Hell’s Gate extreme enduro. With an all-new format for this year, concluding in a 20-minute sprint race, the event posed a fresh challenge for the five-time winner.
      For the first time ever, the event kicked off with a Prologue race on the Friday night. Designed to set the starting order for Saturday’s race, the Prologue was an endurocross style event held close to the hosting Il Ciocco Hotel. Although it provided a great spectacle for the fans, the race results were eventually scrapped due to issues with the course.
      Saturday’s heat race went well for Jarvis. An expert at managing his pace, the Brit did exactly what he had to do over the five-laps, finishing fourth aboard his Husqvarna FE 250 in the cold conditions of the Tuscan hills. The position gave him a good start for the night race, which saw riders set off at 3.30pm for a tough three-hour multi-lap event.
      At the conclusion of the night race, the top-10 riders were given a 15-minute break before contesting the new 20-minute endurocross in the arena area of the venue. In freezing conditions, the riders fought bar-to-bar in front of the record-crowd of spectators to decide the overall winner. With the final results calculated on the sum of the previous legs, Jarvis was announced as runner-up, just a few minutes behind eventual winner Mario Roman.
      Graham Jarvis: “I really enjoyed the racing today, I always do here at Hell’s Gate. It’s been a tough couple of days and I’m still getting used to riding the 4-stroke, but the bike has been absolutely faultless over the entire weekend. It has been pretty close between the top-four all day and it’s all come down to the final 20-minute race off. It would have been nice to take my sixth win at the event, but I’m happy with second.”
      Results – Hells Gate 2018
      1. Mario Roman (Sherco) 3:06:03
      2. Graham Jarvis (Husqvarna) 3:08:57
      3. Travis Teasdale (Beta) 3:12:45
      4. Diego Nicoletti (Husqvarna) 3:32:14
      5. Sonny Goggia (KTM) 3:39:26
      6. Michele Bosi (Beta) 3:46:15
      Husqvarna Motorcycles North America, Inc.
      Husqvarna has continued to expand its professional race team to compete in AMA Supercross, AMA Pro Motocross, AMA National Enduro, GNCC, AMA EnduroCross, and AMA National Hare & Hound championships. Husqvarna team riders are competing aboard Husqvarna FC 450, FC 350, FC 250, FE 350, TC 250 and TE 300 models.
      Rockstar Energy Drink
      Rockstar Energy Drink is designed for those who lead active lifestyles – from Athletes to Rockstars. Available in over 20 flavors at convenience and grocery outlets in over 30 countries, Rockstar supports the Rockstar lifestyle across the globe through Action Sports, Motor Sports, and Live Music. For more information visit: www.RockstarEnergy.com
      Source: Husqvarna Motorcycles GmbH
    • By deanmellor
      My top end went on m 98 cr 125, the needle bearing clip came out and broke apart and shrapnel got everywhere and blew it up. I cleaned out the top end and washed out the crank with the bike upside down. the bike starts up great and seems to run fine but im getting a weird di-di-di-di-di-di-di noise coming from the motor. i tried adjust the power valve and tightening everything but the noise is still there. Here is a link to a video where you can hear the sound. It gets louder as rpm's get higher and at really low rpm barely idling it goes away. I am pretty new to bikes and 2 strokes so any help would be appreciated.
      https://youtu.be/msfU8WCXg8E
    • By RidingWithStyle
      In need of Cycra Handguards (probends) for my bike. Need 1 1/8 clamp size for renthal twinwalls. Message me if you have any for sale at a good price!
    • By Baja Designs
      Hello CRF450R Owners,
      Bailey here with Baja Designs.  We recognize ThumperTalk as one of the go-to sources for information on the CRF450R and we receive emails daily regarding the best inexpensive light setup or purchasing the B1K setup ran by Ox Motorsports.  We would like this thread to be a General Discussion area for members and guests to discuss Dual Sport Kits (DSK), Lights, and Lighting Acessories based upon stock and modified charging systems.  Please Post up if you have any questions or comments CRF450R related!
      www.bajadesigns.com
    • By Chumbag
      I want to get a cheaper used FMF exhaust for my bike. The one on eBay I was looking at had some dents in it. Do dents in the muffler have a big impact on the performance? Also the pipe looks to be turned the wrong way does that rotate? I don't want to buy this if the pipe will not rotate because I think it looks like its turned the wrong way and wouldn't fit.
