08 OEM high compression piston in 06?
Is there any reason the stock '08 piston wouldn't work in the 06? Are there any differences in the head or otherwise that wouldn't allow this to work? I'm thinking about putting one of these piston in my '06 as they are quite bit cheaper than the aftermarket high compression pistons and I would imagine just as reliable.
You are better off just buying a High Compression piston built for an 06.
