05 kx250f ?'s
I'm considering buying an 05 sight unseen, only pictures, but I do have some concerns about the bike. I have heard that the 05 was a bad year because there were problems with the tranny blowing third gear, crank cases cracking at the shifter, and the issue with having to drain the coolant in order to change the oil. The seller says that there are no problems with the bike but I expect that since he is trying to unload the bike. The seller is located across the country so i'm a little leary of the whole thing. What do you guys think? Have you heard of any of these issues?
well just put it this way, the kawi 250fs before 06 were not the best bikes:thumbsup:
havent really heard any problems withthe 05...and no its the 04 that has the single piece waterpump/oil filter cover
Please don't tell me this crap, I have an '05................ But it's been a trooper so far!
-rye
I have a 05 and I haven’t had a single problem with it. :thumbsup:
By the way, it’s for sale also.
-rye
it might of just been a turd in the bunch but my 05 was bad:thumbsup:
bad as in bad or bad as in good?
bad as in bad lol
what was bad about it?
-rye
So is mine bro, good bike.
My 05 runs great! Havent had a single issue with it....if you take care of a bike it will treat you right. Shit does happen just like on anything mechanical. Spend the money on proper maintenance...change oil every couple rides, wash it, clean the air filter, check all the bolts, check valve clearances, keep an eye out for metal flakes in the oil. Simple things can go a long way!
i too would like to hear an answer to this question, in fact i became a memeber to the forum to ask the exact same question. :thumbsup:
were the 05s "problem bikes" in general, or was there just a bad batch?
that is exactly what I keep hearing !!!!!! I heard that the pro circuit team had a ton of problems with this year bike, specifically with the tranny blowing third gear. I don't know a lot about this bike and just want to find out more before I go forward with the transaction. I myself take meticulous care of my bikes, so that wont be an issue. I'm just wondering if there is anything specific I should look out for with this year bike. Thanks for all the input so far.
i def wouldn't buy a bike from across the country. but yea the bike is sweet had mine a yr i ride junior class mx and practice 3-4 days a week and haven't had to replace valves or anything. just normal wear and tear. People complain u gotta short shift a lot but to me I love it because it keeps you from getting lazy always having to shift. it's def a fun bike to ride :ride:
my 05 had a cracked crankcase and it wouldnt shift into second but we fixed and its a trooper now we have raced it everyweekend since may(after we fixed it) and now it could never be better
  • Similar Content
    • By Robert Rice
      Okay so I picked up a 2018 kx250f the other week and took it riding and it was BAD ASS! I have a 2002 ktm125sx and it’ll whoop that thing any day! I’m going to the sand dunes this weekend and gonna use the 6 paddle I used on my 125. Should I be using an 8 paddle with a larger rear sprocket? I wouldn’t want my first experience in the dunes on this bike to be a bummer just because I had the wrong paddle on.
    • By TPA-MX
      Hi guys,
      I have a 2014 KX250f that has a super small hairline, I mean super small hairline crack just under the main engine plug hold on the ignition cover.  You cant really see it, but it "slowly" will leak oil out if let set long enough.
      I would like to permanently fix it.  Right now, I just used some clear silicone on the outside and it stoped the leaking.  However, looking to sell the bike and I want more of a permanent fix.  The 3 options I see are:
      Replace just the ignition cover Replace the entire Stator/ignition cover Use some jb weld on the outside, sand down and paint My questions are:
      On #1, how hard would it be to use my existing stator / magneto items and install in a new cover? On #3, can JB Weld be grinded/sanded down to a smooth finish?  If so, what is the best material to use?  Regular wet/dry sandpaper?  If I go this route, I would want it to look decent, then paint the entire cover black with hi-temp black paint.   What would you recommend?  Am I missing any other alternatives?   Thanks!
    • By rollin30
      I need a subframe for a kx250f and an exhaust system too
    • By rollin30
    • By Andrew Oberther
      I picked up an 09 kx250f as a winter project and it had a chewed up head, and is unrepairable. I was online and found a 2011 kx250f head and was wondering if it would fit. Thanks.
