01 YZ250 miss only around 1/4 throttle
Been working on this bike for the past week. When riding for a good 1/2 hour before working on where the problem is. Fixed most of the issues with the top end.
2001 Yamaha YZ250
Stock jetting is 178 main and 50 pilot
stock needle is N3EJ middle position
I am running 50:1 92 octane pump gas and power plus oil
Air bleed screw is 1.5 turns out and idle screw is 2.5 turns out
Right now it's jetted 185 main and 52 pilot
N3CW needle 3rd position.
Using a BR8ES plug.
FMF fatty pipe w/ shorty silencer
Twin air air filter
Things I have done:
I disassembled the carburetor and cleared all passages and am using new factory jets.
Checked for vacuum leaks around reed cage and carb boot.
I bought this bike used and don't know about the needle that is in there now. I plan on trail riding and hill climbs. I ride it around in 1st gear and slowly roll on the power. Everything after 1/2 throttle is good. Instant wheelie when @ WOT. When I ride around holding 1/4 throttle, it misses alot. I shut the bike off and checked the plug and appears to be lean.I live in HI so elevation is @ sea level. Temperature doesn't seem to matter. Just wondering if it is normal to run this rich of a jet. Will do a compression check tomorrow @ work.
Very :banghead:
if it is lean,it should run better with the air screw closed further.
if it is better with the air screw fully closed but still not right go to a bigger pilto jet and retest.
That is what I was thinking. Pretty frustrating, but I think I'm getting the hang of it. BTW, I found out something interesting. It runs better with the choke on. So I guess I gotta go richer. Thanks again. Very good forum.
Thumpertalk rules.
  • Similar Content
    • By Rick Mcqueen Art
      A tiny clear rubber tube on bottom of carb.  On bottom sort of on side, by floats, the other end just hanging down.  Was it always like this? Or does the other end go somewhere?  Today after multiple trys with kick, choke on/off ,,,fuel keeps pouring out the tube.  This bike has always been hard to start.   Thanx  guys!
    • By Doukis1
      New spark plug, new air filter. Went for a ride and all was good. Hadn't run it in a week and a half. Now it won't start. Getting spark. The plug is dry. Is it possible I over oiled the filter and it has somehow gummed up the carb/ float? Thanks
    • By mbennett95
      My 01' yz125 seems to be requiring a large amount of throttle to get off the line. I've ridden plenty of properly jetted 125's and none required quite so much throttle work from a dead stop. Even slipping the clutch it wont get going without a pretty healthy amount of throttle. Thinking it just needs a clutch rebuild kit and maybe a basket. Any info appreciated!
      If it helps any here is what it has done.
      FMF Fatty, VForce 3 reeds, and an iridium plug.
    • By Sam W.
      Hey all, I just bought a street legal 2005 WR250F. Took it out once three weeks ago. Did about 60 miles on the dirt and 15 on the road, bike ran great. I took it out this past Sunday and was about 75 miles into my ride when the battery died. The battery is cheap, but it is brand new and was on a battery maintainer the whole time while it sat in the garage. I kick started it, and it fired right up. I was on the road for about 5-10 miles in fifth gear when I felt the bike slow down a little bit, and I noticed the sound coming from the bike sounded a bit deeper than usual. About a half mile later the bike started to bog down like it was out of gas. I filled the tank back up and experienced the same problem. The bike began to bog down, then puttered out like it was out of gas. Eventually the battery completely died and I was not even able to kick start it. I trailored it home, hooked it up to the maintainer, waited a couple hours, and the bike fired right up with the electric starter and the choke out. However, it was still puttering a lot when it was idling at this time. If anyone knows whats up, I would appreciate any and all help. Thank you. #Yamaha#wr250f
    • By Ndh87
      I’ve got an old barn find ‘83 CR80R that needs either a new carb or a rebuild kit. I haven’t been able to find either anywhere.
      Does anyone know where I can find either?
      housing, bowl and all the hard parts seem fine, if I can find a rebuild kit with a new float I think I’ll be ok. Right now it runs but only when I leave the choke on, smokes heavily and likes to bog down on takeoff
