Forrest is the best!
I just want to tell everyone about a good customer service experience for a change. :prof:
I ordered some DRC 602 blinkers and the DRC LED Flasher relay that goes with them from Forrest @ Wheeling Cycle Supply last week. They came in record time, with some free stickers for my toolbox.
I installed everything and loved it. Checked my blinkers again, and one is not working. Checked all the connections and found the blinker to have a defect on the circuit board. Emailed Forrest asking what to do, and he wrote back in less than an hour saying a new blinker would be shipped asap. NO PROBLEM.:applause: :applause:
If I bought these at the local stealership, I would have been told "too bad, so sad. No returns on electrical parts." :blah:
Needless to say, if I want it, and Forrest has it, I'm buying it from him. I don't care if I can get it cheaper elsewhere. :thumbsup:
Thanks again Forrest!
:ride: safe all,
Forrest is awesome...I am definatly gonna be ordering from him from now on if he offers it.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
