Im screwed
I was riding my 05 kx250f yesterday when i noticed it was running strange. I rode it for about 1 hour, took a brake then went to start it back up again. I noticed that the compression seemed really weak when i tried to start it and i went to ride it up a hill and it just bogged out. The bike ran great before this all started to happen. Then i went back to the truck and noticed it was smoking!! I had lost almost all oil out of engine from a little whole that is for god knows what in the front of the cylinder above the exhaust. I dont know much baout four strokes or what this is but i know its not good and alot of dirt could of got in there and i could be out of riding for a while till i get some money to fix it if it has any engine troubles.
Dude, that blows! sorry man. hopefully its just a new top end.
how could oil be coming out of the hole on the side of the cylinder..that just leads into the spark plug..unless you are talking about the decompression cover
Yeah, it's just the decomp. plug. If the bike still turns over smooth and there are no strange noises, replace the plug change your oil and start the bike and you should fine.
just replace it. Doesnt cost that much
yea thats it the decompression plug. Where does that lead and could dirt of got in there?
yes dirt could havegone in there.. i suggest opening up the head...i dnt think it really does anything cause most of the newer bikes have an auto decompression
yea but i never really worked on fours so once i open the head then what, look for dirt?
Yeah, you can take the valve cover off and inspect the head for dirt but you shouldn't have any dirt in there. It's kinda hard for anything to go in when oil is flowing out, and if oil isn't coming out then air is. Your head builds pressure so when that plug comes out the pressure releases through that hole.
  • Similar Content
    • By Tedstrom
      Alright so I just rebuilt my 2012 kx250f complete rebuild. I put the motor back in the bike get everything hooked up and ready to go it takes a few kicks at first (obviously) but after it starts it sat and idled just fine for a while then it stalled out. Tried to start it again wouldn't start I took the spark plug out of it it looked good I was dark and wet. I cleaned it then put the spark plug back in it it took a few kicks but started right back up again then after a while it stalled out again and now I can't get it to start again!? Any help would be greatly appreciated thank you guys and girls for reading and hopefully for the help!!!
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
