Anyone have little cracks around there 06 water pump and crankshaft hole cap?
I just bought a brand new(left over) 2006 CRF450R and I noticed some very small cracks around the bottom curve of the water pump and the bottom curve of the cranckshaft hole cap. What gives? Anyone else see this on there bike? Still not even broke-in yet.
Also just below the water leakage check hole, looks like shottie work. Looks like left over metal from the die casting or something like that.
Anyone alse see this on there bikes? Prob not just 06 I'm sure.
Yes I have the same marks on mine. I don't believe they are cracks though...it just looks like poor finish work. I havent had any problems and yes mine is an 06 450 as well.
Let me know what you find out about this...I'd like to know what Honda says about it.
They sure look and feel like cracks, but I would agree that it is very poor finnish work on the right side of the engine...Glad to see it's not just mine. Anyone else? I'd also like to know if you don't have this problem too....
Prior years have this as well. Its been posted in thw 450 forum before. If it isn't leaking, I wouldn't worry about it. You could probably polish them out for looks.
In the same spots as mine?
Casting marks?
I really think if they were cracks...you would notice some fluid leaking.
  • Similar Content
    • By jakebarritt
      I have a 2005 CRF450R with a Trail Tech fan kit installed. I need a little bit larger tank and would like to know if anyone has an aftermarket tank that fits with the fan kit.
      I dont need a monster 4 gallon, just maybe a 2.4 or 2.7 from IMS would do fine.  I talked with both the tank vendor and Trail Tech and neither could give me any answers.
      Thanks guys.
      Jake
      Minden, NV
    • By smythe
      Complete 2009 CRF 450r cylinder head with valvetrain.
    • By NickC18
      So I emailed Factory Connection today to see what spring rate I need for the rear as I’m about 6’2” 220 lbs without gear. I also asked for a baseline front fork PSI to start at. This is what I received:
      Nicholas,
      The spring series we made for your bike is limited when it comes to larger/stiffer rates.
      The spring rate you need is 5.9/6.0 range. We don’t sell that over the counter as it requires special installation process.  So we can’t sell the spring “over the counter”.  It would have to be installed at our shop.
      Fork PSI I would recommend:
      Inner 160 psi
      Outer 11 psi
      Balance 160 psi
      Are they blowing smoke up my ass? What kind of ‘special installation’ could a spring take? I’ve changed and removed them before but not on a 16’ CRF before.
      Also, aren’t those psi settings for the Kawasaki KYB? I don’t think the psf2 have inner/outer/balance do they? Maybe he was having a bad day...or maybe I’m an idiot. FC’s website list there spring as ALS-0059. Can I not just order this spring and install it to set my sag correctly? Help?
    • By johnsbikerepairs
      hi, i have a crf450R 2009, having difficulty setting the idle knob to factory setting.  Having problems interpreting manual Japaneses interpretation.  Can anyone out there assist with the correct factory setting and how i can manually do the setting ie how many clicks out or in etc...   would appreciate any assistance
    • By Baja Designs
      Hello CRF450R Owners,
      Bailey here with Baja Designs.  We recognize ThumperTalk as one of the go-to sources for information on the CRF450R and we receive emails daily regarding the best inexpensive light setup or purchasing the B1K setup ran by Ox Motorsports.  We would like this thread to be a General Discussion area for members and guests to discuss Dual Sport Kits (DSK), Lights, and Lighting Acessories based upon stock and modified charging systems.  Please Post up if you have any questions or comments CRF450R related!
      www.bajadesigns.com
