[[Template core/global/plugins/realFaviconGenerator does not exist. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]] Jump to content
02 TTR225 Idol and Low Throttle Issues
Hello,
I have an 02 TTR225 that I just picked up not too long ago. It was running just fine and dandy last weekend, now I just came in and it will not idol without the choke on. When you give it gas, it just bogs out. If you get it past the bog and keep the R's up, it'll keep going and sound fine if you keep reving it, but when you let off the gas or try to hold a low RPM, it dies. Any suggestions would be greatly appreciated!!!
Thanks!
Joe
