06 CRF 450r MRD exhaust Jetting Question!
I just bought a low to mid spec exhaust from MRD to replace the stocker, I also got the quiet core and Spark Arrestor.
I am currently running a 172 main 42 pilot and JD red needle in the 6th slot from the top. with no other mods to the bike.
After the install of the exhaust the bike starts pretty well, But the low to midrange just doesn't have the snap it did with the stocker it rolls on fine but with quick throttle twist it just doesn't respond like it did with the stock exhaust or have the power the stock pipe did. It has some spots where it burps about 1/2-3/4 throttle while holding steady. I feel like the top end pulls like the stock pipe. I am confused since the bike feels rich on the bottom, sluggish and slow to respond but, you would guess lean do to the new pipe? Maybe with the quiet core and spark arrestor it is flowing less than the stocker?
I pulled the plug today and it looked slightly lean. I just pulled the carb to find it was very dirty! Not good!. So I tore it down and cleaned everything out.
Thanks in advance!
Hey man, my uncle had the same problem with his stock 2003 450. He was told by his friend to put a 45 piolet jet into it. It made a huge difference. We were at Washugal at the time. Going up HP hill, he pulled wheelies all the way up. So give that a try. The jets cost about 5 bucks.
  • Similar Content
    • By Sammy_1101
      Hi Guys,
      So I recently bought a 1997 XR400. I've done some research into getting more power through some basic mods and rejetting the carbs. Though all of the ones I've found have been for post 98 XR400s so the stock carb set up is a lot different. Usually people are opening up the airbox, exhaust ect. ect. and Jetting their carbs up to 160/162 for mains around 60 ish (I think) for the pilot. However for the 97 model this is close to stock for the jets.
      So essentially what Im asking (Just to cut to the chase ) Has anyone got a 96/97 (maybe 98, not sure) XR400 and has done these similar mods, and what sort of jetting have to done as a result.
      Thanks in advanced, also its my first post so apologies if I havent done everything correctly.
    • By Jturn
      38MM Cast SmartCarb. Purchased a couple years ago for a yz250. Don't have the bike anymore, and it has been sitting around for about a year. Used, but in fine working condition. You can also purchase a different needle for different bikes, as well as rebuild kits from their website.
      Asking $250 shipped to continental United States. I can arrange other shipping options at the buyers expense.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By knotduke08
      I know this topic has been discussed in the past, but I have not found any options available for the new 2018 bikes. I live and work for a new Beta Dealer (Auburn Extreme Powersports) in California, and we are having a difficult time mapping the RR-S bikes for full FMF exhausts. We have tried contacting Beta Support several times for this issue to no avail, and we typically are given the runaround when transferring to techs and secretaries. From what we can gather, the FMF flash is designed for the RR bikes, but not the street-legal counterparts. Every time we try to install the FMF map onto an RR-S errors occur, and the programmer screen goes virtually blank. We have heard through the grapevine that some are using the RR maps on the RR-S with success, but we have yet to try it, even on our own bikes for fear that it will permanently erase or damage the CDI. Any and all help or suggestions regarding this topic would surely be appreciated! Thanks, Ben.
