fcr-mx no leak jet ap timing...
sorry but i misunderstood the word wideband...i never did this test
you said """155 main jet iis way small on a 41 as well"""
i hope 155 mj won't cause lean problems to the motor..
i'll try and post results
thanks again eddie,william and everybody, i would have give up without your help.
yes,its to small.you need to be more like a 180 main jet.
:banana: :banana: :ride: wonderfull job eddie ...
i put on a 175 mj (didn't have a 180) , dropped the needle two clips, and
revvvvvvvvv!!!! bike pulls hard! top end ripps and low end is much better.
no more bog:p .
needle position worsened rich condition due to too much ap squirt at sudden opening of throttle as you stated.
Now emr needle is 5° clip but feels like i could drop down one clip more 'cause revving is strong at 3500/4000 rpm. lower rpm has no bog as i said but most of the power comes later.
175 mj feels way better than 155 but then i also feel it could be increased.
as i said my airbox (i put on an e model airbox) is cut on top as much as it could ad all cut on right side.
do you suggest triyng a bigger mj (i only have a 190 at home) or try to reduce hole on the right side to see if its better?
and what do you think about needle clip position? should i try to drop it to improove low end?
thanks
ok i'll try the mj 190 i have
las qt eddie:
i tried the bike without side panel to increase air and see if it was lean at high rpm..it seemed to run the same as if it was on..
how do i know if mj is lean or rich? which simptoms on throttle?
