06 klx 110 cam timing
Where are the cam timing marks on this beast?
You have to remove the left side cover in order to see the timing marks on the flywheel. Top dead center is when your T is pointing at the arrow on the left of your case. There is also a tdc arrow on the head to line your cam up with, match the two and your golden.
Don't forget to reset the tensioner and keep the slack side of the chain on the tensioner side...might be worth the coin to buy a service manual..plus you get the proper TQ specs.
Thanks to both of you, this bike belongs to a girl, the girl friend's son is hitting on. He is a Yamaha mechanic and I am trying to help him.
