clutch ?
when is it time to replace the clutct and how much do i need to replace the plates and springs, the basket or presure plate and hub?
my problem is i have went down in 2 of my races lately and when i get up and go to start it i cant get the thing in neutral to kick it , would that just be the basket is notched ?
any clutch advice is good
cheers rob
ps i hate transmission and suspension stuff
all i know is that this bike has the hardest neutral to find ever.
Yes! It is well known that these bikes are not so easy to get into neutral. Supposed to be in between 1st and 2nd but seems like it is in between the in between!:thumbsup:
Not meaning to state the obvious... but it helps if you rock it a bit when its in gear (so the tyre moves and turns the engine a bit), this free's it up if its jammed a bit under pressure. Basically it wont change gears smoothly when there is pressure on the gear.
But I have gotten the shits with mine and used my hand to... errr... "free the lever". In the nicest possible way of course :thumbsup:
