coolant leak?
i was riding with my nephew on the weekend in heavy sand, and bog (swamp). his crf250x coolant was almost non-existant in the resevoir. we cleaned up his bike but did not see any noticeable leaks. what should we look for or check?
Do you know there was coolant in the res. before you started?
If you can't see any obvious leaks, and you have no 'milk shake', check the small 'weep' hole under the water pump when the engin is hot. The water pump O rings could be passing?
Finaly, check the rad cap. Is it getting soft & opening when it shouldn't?
WR G.
