TTR125 carbs
I have an 02 TTR125L that I'd like to get straightened out.
It has a yz80 (i believe) carb on it and it has a bit of hesitation when twisting the throttle. If you twist fast enough it will die for a second then fire back up. I know it's because it's a two-stroker carb on a fourstroker.
My wife has learned to deal with it but it still gives problems here and there. I'd like to swap it out for a proper carb.. but which one?
What is the hot setup if you were to swap out carbs? I heard something about XR200 carbs...
Thanks!
Todd.
Those work well also, but if you snap it really hard, almost any carb will give you hesitation. I would work on jetting it first. I got mine dialed in pretty well, and I love it.
