Crunch406
What did you do to your DRZ today?
19,288 posts in this topic
I've been training at Fort Irwin for the last month. Other than staring at her picture, I've done nothing.
BUT when I get back I need to clean the oil screen, install the MCCT, and grease both the wheel bearings and lower linkage.
Stiffer springs for the front end may be in the forecast this winter.
Changed the coolant to distilled water and water wetter.
Put on a SME catch can.
Safety wired the oil filter nuts, filler cap, and drain bolts.
Put on axle slider.
Checked that my old GSXR track stand fits the swingarm, and it does, so I'll be losing the kickstand.
That's about it. Preparing for a class next weekend with Trachy.
Re installed my screen after the Blue Light Rally.
Disconnected the clutch isolating switch, behind the headlight shroud, plugged the connectors back into each other closing the loop. Starts without clutching now, just have to make sure the neutral lights on.
Then raised the Triple Clamp on the fork, up to one line down (8mm) from top, instead of two lines down, for a bit more stability in a straight line.
Cut the clutch back to two fingers and the brake back to three fingers, to help with feathering the clutch in hill climbs, and not squeezing on my outside grip fingers.
I gave mine a bath today, I figured hell I've had it 6months already. Its the first time I washed it, boy it was dirty after last weeks muddy rainy all day ride. It almost looks new again... time to get her dirty again :thumbsup:
Cleaned Lube and Adjusted chain. What else needs to be done? Oh, I checked the oil too - yup, there's still some in it :thumbsup:
Washed it, put it on the lift and strapped it down, removed the battery, topped the tank off w/ stabilized fuel, drained the float bowl, covered it up, and closed the garage door. :thumbsup:
Ouch. That sounds too final. I refuse to give up.
after 4 days of neglect i was itching for a ride.. took a short trip to the gym rapped it on all the way awesome!!!
It is kind of final worst case scenario, but when one of those warm winter days comes along (like Tuesday, 75~ish), it'll be ready to ride in under 10 minutes. :thumbsup:
after 40+ miles of muddy, rooted, rocky single track, unloaded 10# of mud, straightened out my bent hand guards, cleaned the chain, relubed it and left it on the stand to dry. then I unloaded the mud from my boots and gear. great day in the trees!!
Yesterday, I went for a ride in north central Washington, overlooking the Columbia River, for about two hours in 24 degree weather. I got to encounter a little snow and ice for the first time on my DRZ. My heated grips came in quite handy. It was a great ride.
I have a 200 DRZ-E with a Baja kit - one of the very first bikes of this series. I spent $1,200 and 12 hours to do long overdue maintanance. It has always run ok.
I have only changed the oil and added gas for 6 years so to get ready for the dirt bike season (California weather is great!) I did the following:
Greased all fittings and shock linkage
Oil and filter
Airfilter change
New Bridgestone tires and checked the wheels for runout - they were great even though I usually ride very rocky section in the Sierra Mtn's all summer
New chain and sprockets 15/50 (up 2 in the back)
New fork springs with race tech valving, fresh oil and seals (Evolution in SJ)
New spring, oil and seals for the shock ($825 for forks and shock)
Replaced the cam chain adjuster with the one talked about here. Tough to get at the inside allen bolt - had to hacksaw my allen wrench.
Checked the valves for the first time since the 600 mile check and they were fine.
lubed the cables
Replaced the front brake pads and fluid
Replaced the coolent, took off the radiators (they were bent but still hold water) and washed the dirt out. Used a screwdriver to straighten bent cores.
Added a new tall seat. Now I barely touch the ground - we will have to see how that goes. The old one hurt after a long day of riding.
New spark plug - first in six years
It ran fine before and runs great now. The suspension should be as good or better than a new KTM.
Took it around the neighborhood and it feels great. I can't wait until this weekend to dial in the suspension.
Any other suggestions for maintanance?
THATS A TESTAMENT TO THE DRZ IF I EVER HEARD ONE,,,RIGT ON :thumbsup:
