Any ideas?
After the tire incident (read previous post), the bike ran great until I had a bit of a spill. It was simple wash-out (rut to deep) and the bike and I landed on the left side. The bike was running after the spill but I couldn't pull the clutch in when I picked it up (stick was in the way). After I got the bike up and running it idled like crap. It would run OK for about 6 seconds and then slow down until it shut-off. If I kept the gas-on, it wouldn't stall so it's not a fuel-flow problem, it's an idle problem. Could a wreck change the idle? I don't think so, riding nasty whoops would have the same effect. Any clues?
I don't understand how a throttle cable issue would cause the bike to idle so low it kills the engine. If I kept the throttle open it would run fine, it was letting go of the throttle that caused the bike to stall.
Sorry my bad. Just throwing something out there. I saw the words crash and throttle and instantly thought throttle cable due to other posts. Although they had a rev problem not an idle problem like you mention.
So can you adjust the idle and make the bike run fine? Maybe your stepper was jarred and is not acting right now. Or after a few recent posts maybe the throttle body has a problem. Just throwing ideas out there for you.
Good Luck.
HR had a post on the stepper. I tried to search for it, but couldn't find it. Given the suddeness of you problem I'd say 'something' happened during the fall. Usually electrical problems are more binary, but I wouldn't rule them out. If you just start taking it apart something may show up as looking funny.
Jason,\
my dealer is doing the stepper work under warrenty, you may want to check with them if you trust them to do it right.
mook
Jason,
Just to eliminate it from the realm of possibility I would check the wiring harness carefully paying close attention to the O2 sensor wire and I would check your stator wiring from the flywheel up (see the SB's for both the o2 sensor and the stator wiring prior to your inspection). If both are OK I would then move to checking all ot he engine sensor connectors starting with the air box temperature sensor.
Process of elimination may be the best method of resolving the problem.
Ron
  • Similar Content
    • By motomutt
      I just bought an '02 605 super motard. The manual says the forks are Paoili. The previous owner says WP. Anyhow, the compression adjustment is on the SIDE of the fork at the bottom. There is no "turn all the way clockwise til bottom, then count the number of clicks out" as is typical. The screw just continually turns. There numbers 1 - 8 clockwise in a circle around the screw. I'm a Clydesdale so I set it at 8. What forks are these ? Do I only get 8 compression settings ? Is there a malfunction ? Thanks in advance. Mutt
    • By motomutt
      Just picked up an '02 supermotard with extra dual sport wheels. Waiting on a battery but everything seems dialed in. Where can I get parts ? Is it the general consensus that the stock carbs aren't great ? What's the alternative. I'm gonna have lots of questions. Thanks in advance for your $.02. Mut
    • By wachterxc
      My wheel has some pretty serious lateral movement. I dont have a truing stand but my buddy could lend me a spoke torque wrench. Would I be able to eliminate the lateral movement only using the the torque wrench ?
      regards
    • By Max John
      Hi guys, just looking for a new set of graphics and plastics for my bike, I have a 2012 ktm sx125. Does anyone have a specific place they aware by for graphics? Does anyone the the best place to get graphics? Thanks guys.
    • By oh.snap.mike
      First of many posts hopefully
      During January we filmed a commercial for Mitas Tyres here in South Africa. It took 2 months of pre-production, 1 week of filming and 3 weeks of editing to arrive at the final video.
      The riders were David Ellis on the off-road bike (Husqvarna FX450), Altus De Wet on the enduro bike (KTM 300 EXC TPI) and Louis Knipe on the adventure bike (BMW R 1200GS LC)
      I've had heaps of questions of how we went about filming the video and so I've decided to open up the line to whatever anyone would like to know.
      Ask me anything.
