Airboot and Carb
Just me or does anyone else have a hell of a time getting
the airboot back on the carb when you are putting your subframe back on?
I have lost skin of my knuckles doing this. Not from the actual job but punching the BLOODY BIKE. I have no patience and this has to be the most frustrating job on the bike.
When I install my subframe after cleaning I have been using piece of wood molding to push the air boot back on the carb and this helps keep the frustration down for myself.
It's a bit tight I know but it never took me more then 10 minutes. Just make sure you put some WD 40 on it (the boot) and just put the top subframe bolt in loose so you can move the subframe a lttle. Makes sure you view it from every possible angle too. For me I think the last portion that seems to go on is the top or brake pedal side. Patience is the key and punching your bike will only get the bike mad at you next time your out riding. It just might spit you off!!!! :):D
Hey Huffa
I can change 2 tyres have 2 beers watch the latest Crusty Video (Skipping Through the S H I T) so this airboot thingy should take less than 10 seconds :):D.
AND the bike spits me off no matter how nice i am too it, so our relationship is at the crossroads.
Just spray a little windex on the inside of the boot and it slides right on. Spit works, but windex doesn't dry as fast.
That's interesting... I just now posted a reply regarding setting the sag, and warned to be very careful getting the air box and carburetor mated back up properly.
I finally settled on using a long, flat-blade screwdriver to lever the connecting tube against the carb, from the bike's left side. And then used that same screwdriver to push from the back.
Get a flashlight to make sure you do have it mated. It's dark and hidden in there.
I finally can do this in 5-10 minutes.
Try fitting the 4 airboots on 4 carbs on a street bike, with no room to work. It took me over 2 hours to get my ninja back together. I also broke a chair that was there, just to save the bike from my frustration.
To put CRF together I bolt up the subframe, but keep it loose so it can move a little. I put a thin layer of grease on the airboot, and slide the bottom on first. Then I use a long flat bladed screwdriver that's been blunted and push the top on. Doing this takes no more than a minute or two for me. A trick is to keep the clamp away from the contact surface so the rubber can expand fully.
Honestly, I don't have too much trouble. Less than 5 minutes each time. I put a little grease on the carb collar so that it will go on and come off a little more easy. I also tend to leave the airbox in the subframe.
Line it up on the top, reach in grab the tab on the lower part of the boot, pull the tab while pushing the airboot from the rear. Be sure that the fastening ring is fully loose (I leave the screw out of mine). A few skinned knuckles, but few problems.
Guess I got lucky on mine yesterday. Top was on after lining up the subframe, and for the bottom, just pulled on that wonderful tab Honda was kind enough to mold in, and that was it. But I'm still going to look again today with a flashlight.
Maybe having struggled with this on a KLX300 and aftermarket carb, anything seems easy. Taking the carb off the klx made me cry and bleed often.
Just lube it up baby! You know those tight holes need lubrication! Make sure the clamp is outta the way and try to start it on at the top first when you align the sub-frame.
All these meathods are very good starting points but to made this a quick job I use a Snap On tools cotter pin puller part number A173, this tool is a screw driver like handle with a couple of bends in it and a narrow tapering pointy end that can be slipped between the air boot and carb to help slip the boot on. I'm sure this tool is available from others as well.
  • Similar Content
    • By aminem
      my kill switch is not working and i had bought a new one , My problem is that , i cant disconnect the OEM kill switch . is it a trick to disconnect it !?
      plz Help
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By desert520sx
      I have a 03 450 that I just got and it runs great! I love my bike and am big on preventative maintenance. I have searched the threads on TT and have not found any descriptive threads on how to check valve clearance or adjust them. Just by looking at them, I can see that the intakes need to be shimmed and the exhaust valves can be adjusted quite easily unless one needs to be adjusted differently than the other.
      I tried to do it last night, and lined up the marks on each side to get the piston to TDC to check adjustments and could not get any readings on tolerances on either the intake nor the exhaust. I moved the crank a little bit forward and got a .011 reading on the exhaust valves. I read in a thread that the spec was .011" for the left one and .014" in the right for the auto decompressor. The spec I am using for the intakes is .006" Are these specs correct? :excuseme:The only issue is that the adjustment for the exhaust valves is one and the same. Different from my KTM where you can adjust each valve individually.
      No matter where the cam was on the intake valves, I could not get any readings. Does anyone have a thread, website, downloadable manual, or article on checking and adjusting valves in these beasts?
    • By Eric Schrader
      I am selling my 2007 Honda CRF 450-R which is set up for desert racing (Track/desert). It has an 18" rear tire with a heavy duty setup (see description for details). The bike screams and has a Tokyo mods carb mod with the 10x ignition mapping (currently set to a handlebar switch for smooth power and max power). Gas tank is a 3.2 gallon IMS dry break tank. V4 steering stabilizer included. Precision Concepts suspention, Bike is set up for 6'4" 175lb rider. Zero oil leaks and well maintained using a preventative maintenance method with the best new parts each time. Receipts for all items can be provided. About 20 hours on the rebuilt head. Carb just rebuilt. Starts cold in just 2-3 kicks. 100% reliable bike as long as you turn the gas on.  Current CA Red sticker and original title.
      Expand above to see details
    • By bigg_stevee
      I recently replaced water pump and seal after I noticed that my '02 CRF450R was spilling coolant on easy trail rides. After the water pump swap (which was successful), I noticed the same problem. It's interesting - the bike only spits coolant (I mean a LOT of coolant) after passing anything above 1/2 throttle. The bike makes this weird 'gurgling' noise, like trying to suck through a straw when your glass is almost empty. This is weird because I properly bled/ burped the radiators with coolant, and filled them to normal operating levels. The coolant spills through overflow hose.
      anyways - I swapped the radiator because I thought maybe the bike was running hot. I purchased oversized radiators, bought a 1.6 radiator cap (with a temp gauge) and bought engine ice. The bike runs very very cool - the temp gauge allows me to see this. Still, the bike shoots coolant out of the overflow after going above half throttle, making the same weird gurgling noise when it does. Bike has all of its power, top end was replaced not too long ago.
      I'm lost and don't know what is wrong with the cooling system in my bike. How do I make the bike stop shooting out coolant, and stop making the weird gurgle noise??? Any advice would help me!!! Thank you!
