smaller rear sprocket...? edit version
Hey all,
I found that Im riding alot more on the street then I expected when I was
shopping for the bike. It cruises nice between 70-75 on the freeway,
although it seems like Im reving a bit much. I would like to go to
a smaller rear, just enough to make my freeway cruise tone down the revs
a bit. Id like to cruise with traffic at 80-85 without reving too much.
Seems like everyone on the freeway is going 80-90 now anyway...
What size would I need to cruise 80-85 without reving too much.
Any suggestions...? Cheapest place to find them...?
Any how too pages on sprocket swaps around...?
Thanks in advance, Duane
your bike comes a 44 tooth want an even smaller one if your bike revs too much for you.going larger will only make it confused on what your after?your gearing is already ridiculousy high.
yeah your right, i got my math wrong, I guess I need a smaller rear
to get a higher top end, I guess thats what Im looking for, not too much
just enough to eliminate the buzz @ 80-85mph and make it a bit more
freeway freindly for longer trips at speed. So I have a 43 stock, if I went
to a 40 would I loose too much of my low end...? I guess its a trade off...
So I have a 43 stock, if I went to a 40 would I loose too much of my low end...?
43 stock? Didn't your bike come with 15/44 gearing? Have you thought about swapping out the countershaft sprocket instead of the rear sprocket?
I dont know what stcok is I was going by what burned said, I thought it was 43, guess its 44.
I guess changing either would do the same thing and give me
the same outcome. I could go to a 17 or 18 front, or a 38-40 rear
to get the higher top end Im looking for. All I really want is a more comfortble feel on the freeway at speeds around 80-85, at that speed now it sounds like Im reving too much, wish I had a tach...
Guess Ill keep the trailwings for a while since in only 3 weeks I have
1400 miles, only about 100 of them are dirt...:)
I was just looking at the Sprocket Specialists web site and it appears that 16t is the biggest they make for our bikes...not sure if anyone else makes any bigger sprockets. I'd give the 16 a try - each tooth up front makes a big difference. I went from a 15 down to a 14 and it was quite noticeable. The reason I mention changing the front is that I think it's easier and cheaper to change the front sprocket instead of the rear. Hope that helps!
thanks for the info, Ill take a look at their site. Makes sense to change the
front if its easier. Ill probably go with the 16, if thats still not enough
I can always do the rear. Thanks again.
No problem - good luck and keep us posted on how it works out for you.
to the best of my knowledge, you cant mount larger then the 15 up front. Read that somewhere but cant remember where it was. Im sure someone here knows, if not sprocket specialties would.
Dude, 85mph on this bike is too fast! Anyhow, there is direct relationship between any gearing ratio change and the rear wheel speed. IOW if the ratio of front spocket to rear sprocket is increased by 1.1 times, the road speed will increase by 1.1 times. However, at those speeds wind resistance plays a major role and you very well may not change or even decrease your top speed because of the decrease in rear wheel torque. Trial and error is the only way to find the best combo. Let us know what you find out in terms of what gearing change yields what change in top speed.
I found this cool gear ratio caculator on a Baja Buss sight from australia. You can down load it for free. Use the tool bar at the top to use it for motorcycles and get out your owners manual for all the gear info. Be sure and change it to imperial for MPH.
I would leave it as it is. Like it was said it's already geared very high. Too high for tight downhill off road sections. But if your just riding on the street and on the freeway for that matter , I could see wanting a different ratio. 85 is awfully fast for your bike , I think I got mine close to 90 once and it felt waaay to fast for such a light bike. Maybe you should get a street bike too? :)
15t is as big as you can go on the front.i dont think it will pull any smaller than 44 on the back.thats and already ridiculous ratio any way.try a 40 and see what happens.the SM guys run 38 but thats with a 17 inch wheel.try it. :)
I've ridden a lot of highway, and I wouldn't recommend changing the gearing for higher speeds or lower revs. It's not really a highway bike, it has a high center of gravity and wobbles at high speeds. Even if you can keep it pointed in a straight line, how is it going to handle in an emergency situation? Riding motorcycles is risky as it is -- why increase your risk level exponentially?
You might have purchased the wrong bike for your needs. If you're looking for a bike that costs about the same as the drz, will go fast on the highway and do moderately well off road, I'd consider a KLR650 trade in. They don't sell as well as the DRZ's so you might get lucky with the right dealer.
The DRZ is kinda lame offroad with the trailwings anyway, and will really suck with higher gearing.
sprocket specialties got back to me and said the 16 will fit the DRZ, they said that was my cheapest route to test. I have had my bike to 95, really revving, but that was once, didnt have any front shake problems. I cruise with it now at 75, but it still revs a bit high I think. The bike is very stable at speed in my opinion, at least on the trailwings. I wouldnt want to
cruise @ 75 for very long on a set of MT21's...;-)
Im going to order a 16 and see what that does for me, and yes I probably do
need a street bike also. As soon as I pay down my kawi card for the KLX.
I might go the supermotard route and save up for a set of 17's, then again
I could probably find a nice used street bike for the same cost it would
take me to supermotard my KLX...;-)
Thanks for the tips and advice.
Please keep us posted on the 16T when you get it.
It would be neat, the quick gearing change possiblities.
14/47 15/47 16/47.
Ask Sprocket Specialists if it works with your stock chain-guide though, you will need a new or modified case saver also there is a rubber buffer on the swing arm that has not much clearance even with the stock 15T.
looks like its time for another email to SS, I was under the impression
from their email it would fit without mods, but if your right about the
front clearance then going to a 42 or 40 rear would be my next option.
got another response back from SS.
I have never had feedback that it doesn't fit but if other owners think it
is too tight then it might be. We can still achieve the gearing with the
rear sprocket.
Guess Ill save myself the ordering and return hassle with the 16t and opt
for a 42-40 rear, I do like their anodized colors anyway...
Better stick with the trailwings 606's over 70mph get real shaky on the street
  • Similar Content
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
    • By drzvfr
      I did the fix last night and took some pics and notes to make this easy on people that haven't done it and want more detail. Please chime in if you think I've missed something.
      Required Tools:
      Set of Allen wrenches
      #3 Phillips screwdriver
      small flat head screwdriver
      8 & 10 mm sockets
      13 mm open end wrench (I needed this to remove my skid plate)
      snap ring pliers
      gasket scraper
      compressed air
      Required Parts:
      New clutch cover gasket, Suzuki Part # 11482-29F00
      Tube or can of RTV sealant
      Oil filter and oil (if you plan to change the oil)
      1. Remove your skid plate (if you have one). I have a Tonn's skid plate and it was in the way.
      2. Remove right side radiator cover.
      3. Unbolt the rear brake lever. This will require removing a cotter pin on the backside of the bolt, and then the bolt itself. I was able to swing the lever far enough out of the way without completely removing it from the bike (see pic).
      4. Drain the coolant. This requires removing the radiator cap and the small bolt on the water pump, which has an aluminum washer on it. I rocked the bike from side to side to get most of the coolant out of the bike.
      5. The oil, two options here. You can either drain the oil and remove the oil filter or you can do what I did which is lay the bike on its left side to keep the oil from pouring out of the engine when you remove the clutch cover. I still removed the oil filter so I could clean the clutch cover with brake clean after scraping the old gasket off.
      6. Loosen the hose clamp on the coolant hose that attaches to the top of the water pump and fold the hose out of the way.
      7. Remove the water pump cover and the clutch cover by removing the bolts holding them on. Note that some of the bolts are of different sizes so keep track of which hole you pulled them from. Also, not all of the bolts need be removed, see the pic below.
      8. Remove the old gasket from the clutch cover and/or the engine with your gasket scraper. I then cleaned the clutch cover with brake cleaner as it was fairly oily.
      9. With your snap ring pliers, remove the snap ring from the plastic gear on the clutch cover seen here:
      10. Remove the plastic gear.
      11. Push out the metal pin and remove the washer underneath as seen here:
      12. With a screwdriver or whatever your preferred tool, remove the “E” clip as seen here:
      13. After removing the “E” clip push the water pump shaft out of the clutch cover.
      14. You will now have the part in your hand that needs fixing. Remove the porcelain gasket at the bottom of the shaft by blowing it with compressed air. Don’t not pry it with a screwdriver as it could damage the gasket. Mine was stuck fairly well so I sprayed some WD-40 on first to loosen it up.
      15. If you used WD-40 clean the shaft and gasket with some brake cleaner and then apply the RTV sealant to this area (I reused this pic as its perfect):
      16. Push the gasket back down flush on the shaft wiping away any excess RTV that may flow out.
      17. Reassemble the shaft into the clutch cover in reverse order as listed in steps 9-13.
      18. Place your new clutch cover gasket on the engine and then place the cover back onto the bike.
      19. Put the bolts back into the clutch and water pump cover and tighten equally. I could not find a torque setting for these in the manual so I snugged them evenly.
      20. Put the oil filter or a new one in the bike and put the oil filter cover back on.
      21. Re-attach the brake lever and tighten the bolt to 21 ft lbs. Be sure to install a new cotter pin on the backside of the bolt.
      22. If you drained your oil, refill the crankcase with the proper amount. If you didn’t drain the oil be sure you have enough in the crankcase from oil lost from removing the clutch cover.
      23. Let bike sit for 24 hours to let the RTV set up before adding coolant.
      24. Re-attach the coolant hose to the top of the water pump and tighten the hose clamp.
      25. Fill the radiator with a “Silicate Free” anti-freeze and put the radiator cap back on and tighten the radiator cap screw.
      26. Put the radiator cover and your skid plate back on the bike.
      27. You are done, go ride!
      This post has been promoted to a wiki
      Since I've been getting a few requests a week to e-mail the re-jet instructions word document (offered to send it to someone in old post that lives on) I thought I'd throw this post together. It is perhaps the one stop shop for 3x3 mod info: the master 3x3 post
      The 3x3 Mod
      So what is the 3x3 mod anyway? Well, this mod is basically re-jetting your carb and allowing it to run to its full potential. This mod can be done by even the most newbie of wrenchers out there. 3x3 refers to the size of hole that you will need to cut into the top of your airbox where your snorkel currently is. Don’t worry, you are not carelessly risking getting water into your engine by removing the snorkel. The bread and butter of the mod is the taper of new needle which you will get with your kit.
      Jet kits can be found through the TT here
      Scroll down to the bottom to find the right kit for your DRZ
      If you purchased a S kit for SM by accident don’t worry it will work (different jetting specs are used, just ask!)
      There are some great instructions outlining the procedure and here are two:
      bayoubikebruiser’s post is a nice one (Good Job BBB)
      Note that BBB followed the TPS sensor wire back and detached from the clip it there rather than removing the TPS off the carb.
      Another read is the attached word file (which i convereted to pdf and can be found here for your convenience) which has ‘been around the block’ to say the least.
      Sample Jetting recommendations (note: these are different for different elevations and different bikes)
      - 150 main jet (155mj for full exhaust system)
      - 25 pilot jet
      - 2nd clip on needle from top
      - 2.5 turns out on fuel screw
      - 140 – 142.mj (bigger for exhaust)
      - 25 pilot jet
      - 4th position from top
      - 2.5 to 3 turns out on fuel screw
      Burned’s fuel screw setting method:
      with the bike warm and idleing turn the fuel screw in till the idle drops/misses.then go back out till the idle peaks/smooths.
      this should happen between 1 and 3 turns out.
      if you end up at less than 1 turn you need a smaller pilot jet.more than 2.5 (or 3 turns on a cv) you need a bigger pilot jet.
      choose the appropriate size and retest.
      The 25 Pilot jet part number for TT is:
      So… now you have the info that you need, get to it! Your bike will sound better and rip a little faster; get ready to grin!
