Difference between SX and MXC engine?
What is the difference between the 525 SX engine, and the 525 MXC engine? From the off-road.com website, it appears as if only the SX recieved a bunch of refinements.
Regards,
Andrew
From KTM's 03 specs:
525 SX Racing 4-Stroke
Extensive efforts have boosted the performance level of this engine.
Crank gear
Featuring a slimmed-down inertia weight, the new 525 SX crankshaft is about 800 grams lighter.
Cylinder/Cylinder Head
A new cylinder head, whose port cross-section was increased from 39 to 41 mm, and a new Keihin FCR-MX 41 carburetor with hot-start knob, as well as lighter valve springs improve peak power.
Through a change in timing, the modified camshaft boosts peak power and increases the maximum r.p.m. .
Ignition System
New digital control electronics and a lighter weight ignition system deliver improved throttle response.
Thanks John B
What about the MXC engine? I am riding a 520SX with E-start and 5th & 6th.
See Ya
Okie :)
