confused.....crank case oil/tran oil 03 CRF450R
manual says 10w-40 for crank case but not very clear on trans oil. but the way i read it . it's the same in both.
Make sure for the tranny you use the no moly oil. I can't remember off the top of my head the weight of the tranny oil but I know the manual says no moly. I use the honda tranny fluid w/o moly
Without MOLY is key. I use Honda 2 smoke trans oil, but any oil that meets the spec. listed in the manual is fine.
Be sure to follow the Tranny fill procedure in the manual...add the recomended the bike 3 minutes....wait 3... THEN pull the oil level bolt and add oil until it comes out the hole.
I use 10W40 Castrol in the tranny and 15w50 Mobil 1 in the engine.
Another thing that I have picked up from TT is to measure the tranny fluid in a cylinder etc so you have the mfg specified amount and then add all of the fluid. The reason I don't use the check bolt is that I have heard it is not that accurate. If you buy a funnel for 2 or 3 dollars at the auto part store you can measure the exact amount and add the correct amount without using the check bolt. This way you know for sure you have all the oil you need.
I've been told the transmission is basically the same as a two stroke tranny. I'm curious why most 2 stroke tranny oil is around 75/85 weight and the manual says it's okay to run 10/40 in the CRF. So, this must mean that it would be fine to run 10/40 engine oil in any two stroke transmission?
I run Golden Specto 10/40 in my engine side and the Honda (HP4?)85W tranny fluid in the transmission.
Your right, I used to run 10w40 in my RM125 case. The manual said to us 10w40. On my 450 I use Mobil 1 15w50 in the engine and valvoline 10w40 in the tranny. By the way, my tranny oil in my '03 is a lot cleaner than the '02 was by comparison.
So all this time I was wasting money on buying the expensive gear lube when regular engine oil would've worked. :)
In my YZ400F, I ran the Mobile 1 15w50 and never had a problem, even though the tranny is not seperate from the engine. I had heard on TT that Mobile had added the dreaded friction modifiers to their 15w50 and did not suggest using it in wet clutches. The other day I was at Autozone and picked up a bottle and started reading the back and didn't see anything that looked different from when I was using it in the YZ. Is that why you are using Valvoline in your tranny, antman? Also, are you using the regular Valvoline that you buy off the shelf at your local auto store?
You heard from people that didn't read their manual! :)
The check bolt works PERFECT if you follow the instructions in the manual. When the CRF first came out, some folks thought it worked just like any other bike...pulled the bolt, added oil...stopped when it came out the hole.... WRONG If you follow the procedure in the manual ( where have I heard that before?hmmmm) it works fine! :D
The crankcase oil capacity is .62 qt....drain out all your oil, fill up a bottle with .62 of a quart of oil and start pouring it in. See how much oil is left in the bottle when it starts flowing out of the oil check hole. Theoretically there shouldn't be any.....I bet there will be some left in there.
I have been using Amsoil in my bikes for a few years now with great resaults. I talked to the tech department at Amsoil and they recomend the 10-40 AMF motor oil. This is great for your motor and wet clutches. This is what Mike Larocco uses. If you want any information on becoming an amsoil dealer please let me know as this is what I did and now sell at the races to help support my habit. You can change your oil less with the full synthetic oils so It saves $$.
Good luck and have fun riding.
I stopped using Mobil 1 in my tranny due to the changed formulation. Supposedly they just lowered the levels of zinc and phosphorus according to a tech at Mobil 1 who I called personally. He did say that I should use a motorcycle specific oil (bullshi**). The 15w50 worked great both sides before. I wish they would not have changed it. I don't have the balls to chance it so I just use regular valvoline 10w40 in the tranny now. I know that Mobil 1 will be fine in the engine. I just started using it this past weekend on my '03 (after break in). I change the oil real often anyway, so I am not going to sweat it. By the way, my tranny oil is a lot cleaner in my '03 than my '02 was after two rides. I think the clutch bushings are made of a different material for '03. Cheers!
this is from the artical in MX action
i guess i will do what manual says. run for 3 min. then add.
So, what should you do? Here is a possible solution. When you are changing the CRF’s transmission oil, fill the clutch up to the check hole and then start the engine and let it run for three minutes (on the stand). Turn the engine off and wait three more minutes. Now, refill the clutch cavity with the additional oil.
A better fix would be to measure out at least 600cc of oil into a graduated beaker and then not ride your CRF450 until you get all 600cc into the tranny. If you have split the cases or cleaned the cases out with solvent, use 670cc. "
anyway, as long as i use 10w 40 without the molly stuff i'm ok. right?
Yes, no moly in the Trans side.
I use pro honda on both sides and ive had almost 3 good years of HARD racing and no problems. they both use the same oil.
the post before your's was the day i bought my 03!!!!!!!!!crazy!!!!!!....this thread is nearly six years old!!!!!!!!
Anybody used Torco oils in CRF450R?? My mechanic guy likes gold Honda oil (no moly) in the tranny...............and says its ok for the crankcase too. so I've been keeping it on both sides. My kid wants to switch to Torco.
It would be fine to run 10w40 in a two-smoker!
  • Similar Content
    • By aminem
      my kill switch is not working and i had bought a new one , My problem is that , i cant disconnect the OEM kill switch . is it a trick to disconnect it !?
      plz Help
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By desert520sx
      I have a 03 450 that I just got and it runs great! I love my bike and am big on preventative maintenance. I have searched the threads on TT and have not found any descriptive threads on how to check valve clearance or adjust them. Just by looking at them, I can see that the intakes need to be shimmed and the exhaust valves can be adjusted quite easily unless one needs to be adjusted differently than the other.
      I tried to do it last night, and lined up the marks on each side to get the piston to TDC to check adjustments and could not get any readings on tolerances on either the intake nor the exhaust. I moved the crank a little bit forward and got a .011 reading on the exhaust valves. I read in a thread that the spec was .011" for the left one and .014" in the right for the auto decompressor. The spec I am using for the intakes is .006" Are these specs correct? :excuseme:The only issue is that the adjustment for the exhaust valves is one and the same. Different from my KTM where you can adjust each valve individually.
      No matter where the cam was on the intake valves, I could not get any readings. Does anyone have a thread, website, downloadable manual, or article on checking and adjusting valves in these beasts?
    • By Eric Schrader
      I am selling my 2007 Honda CRF 450-R which is set up for desert racing (Track/desert). It has an 18" rear tire with a heavy duty setup (see description for details). The bike screams and has a Tokyo mods carb mod with the 10x ignition mapping (currently set to a handlebar switch for smooth power and max power). Gas tank is a 3.2 gallon IMS dry break tank. V4 steering stabilizer included. Precision Concepts suspention, Bike is set up for 6'4" 175lb rider. Zero oil leaks and well maintained using a preventative maintenance method with the best new parts each time. Receipts for all items can be provided. About 20 hours on the rebuilt head. Carb just rebuilt. Starts cold in just 2-3 kicks. 100% reliable bike as long as you turn the gas on.  Current CA Red sticker and original title.
      Expand above to see details
    • By bigg_stevee
      I recently replaced water pump and seal after I noticed that my '02 CRF450R was spilling coolant on easy trail rides. After the water pump swap (which was successful), I noticed the same problem. It's interesting - the bike only spits coolant (I mean a LOT of coolant) after passing anything above 1/2 throttle. The bike makes this weird 'gurgling' noise, like trying to suck through a straw when your glass is almost empty. This is weird because I properly bled/ burped the radiators with coolant, and filled them to normal operating levels. The coolant spills through overflow hose.
      anyways - I swapped the radiator because I thought maybe the bike was running hot. I purchased oversized radiators, bought a 1.6 radiator cap (with a temp gauge) and bought engine ice. The bike runs very very cool - the temp gauge allows me to see this. Still, the bike shoots coolant out of the overflow after going above half throttle, making the same weird gurgling noise when it does. Bike has all of its power, top end was replaced not too long ago.
      I'm lost and don't know what is wrong with the cooling system in my bike. How do I make the bike stop shooting out coolant, and stop making the weird gurgle noise??? Any advice would help me!!! Thank you!
