Clutch Questions
Hey, this is my first post here on TT. I have been riding thumpers for about 6 years, only XRs, until yesterday when I bought a 99 yzf400. I love it so far, but I think the clutch is slipping. How hard is the install on it? I just ordered a new kit today to do the install myself. Do you really need the clutch tool? The vice grip looking things? I have put new clutches in cars, and I am very mechanical. I would appreciate any information, or good web sites that I could use to find information. Oh yeah, I already have done a few searches, but didnt find anything. Sorry if this has already been posted,
come on, 30 views and no post. someone help the new guy out.
Ok i will stop you suffering young padwan learner
Clutch tool is needed Yamaha or after market is good, local shop should have one.
Torque wrench
Breaker bar (Not to be confised as Biker Bar like some think)
A manual did you get a manual?
if not Clyners is good or buy the OEM from yamaha.
you can also look at this web site
look under Tech Articles and scrool down to "YZ426 Complete Shop manual"
I know you have a 400 but the info should be the same, some of the 400 owners should be able to clairfy Torque settings.
Hope it helps and welcom Young PadWan Learner
Hey, I have the OE manual, and it has helped. I went to the yamaha shop by my house this after noon when I was finished with class. They told me that they do the clutches all the time, and dont use that clutch holder tool. You think that it is necessary? I also ordered the moose clutch kit. It has the springs, and new fiber plates. I really appreciate you helping a new YZF guy out. thanks a lot,
Did they tell you that they have a compressor with impact wrenches ?
If not then thats why they dont use the spanner tool. I assume you do not have a compressor, Correct ?.
Since you do not have a compressor, you dont have an impact wrench Correct again?
Go buy the tool
I actually do have an impact wrench. I love air tools. I work a lot on cars. I have an acura integra type R that I race a lot. What is the correlation between the impact wrench, and that tool? Just wondering.
Ok I am trying to help here,
You have identified a few things
1: Your Mechanical
2: You have a manual
3: You have Air tools
4: you have a car
5: You love air tools
6: You need a clutch
7: You ordered parts
8: you asked questions
9: you continue to ask question
10: your asking more questions
11: I have the answers
Use your mechanical knowledge to read the manual, thus satisfying your love of air tools, and maintaining the quality of your bike with well spent money on a new clutch.
Outside of that the correlation of the impact tools and the spanner is this.
If you don't have one use the other :)
haha, well until I post another question, this thread is closed. I do appreciate all of your help
  • Similar Content
    • By Zack Ailing
      hey guys just picked up a new project bike. Its a 2008 Yz450f with a big bore kit and a stroker crank. The total cc of the engine is now 499. It runs on race gas and will be an absolute monster when shes ready to rip. I will continue to make more videos on the bike so stay tuned Link to the video:
    • By High On Octane
      2005 YZ450F, Athena Big Bore, Power Bomb, Q4.
      Ok.  Last fall after a decently hot day at the track, I noticed coolant leaking from the weep hole on my water pump after pulling into the pits.  Ordered an Athena re-seal kit, put it all back together and didn't really get a chance to ride it.  3 weeks ago, went out to the track, and after about 20 laps, it started leaking again.  Kept filling it with water to get thru the day, never ran anywhere close to dry or empty, jut a cup or 2 low.  Ordered a Hot Rods re-seal kit with bearing and also ordered a new w/p shaft.  Did it all again and got it back together, ran it, and as soon as it got to temp, it was leaking out of the weep hole again.
      So, what the heck am I missing?  I'm totally stumped on this one.  Is something wrong with my case cover?  Do I need to replace the w/p itself?  I'm feeling like I should've just ponied up for the Boysen in the first place, and now it's biting me in the butt.  Any help or suggestions is greatly appreciated.  Thanks!
    • By Awheeler25u
      Alright guys, my 04 YZ450f runs fine minus some slight backfires when decelerating (need to adjust fuel screw). The other day when I was done checking my valve clearances I changed the oil and filter and put the bike back on the stand, kicked it a few times without the ignition coil in to get some oil flowing got off and noticed a little drip spot on the ground, it was no bigger than a dime so I thought nothing of it. Started the bike with no issues took it for a quick 10-15 min ride, came back to the garage to find out my whole case was soaked with oil and it started pooling in the low spots on the clutch basket side. I cleaned all the oil off and took it out again for 5 mins to try and see where it was coming from, here are my three possible places but nothing directly leads me to believe it’s any of the three either.
      1. Decompression plug area
      2.  Valve cover gasket leak (not really sure because the amount of oil leaking Looks to be a large amount
      3. Oil tank (bad weld or cracked weld somewhere
      what are you guys thinking?
    • By bofar
      Hey guys. I could really use your help diagnosing an issue that came up riding today. Bike is a 2013 YZ450F. Well maintained and haven't had any issues until now. Both the oil and coolant are new and levels are to spec.
      After riding for about an hour in the sand dunes, I noticed a grinding going on on the right side of the bottom end (from what I could tell). When I looked to see what was going on my kickstarter was vibrating and grinding really loud. This was a different sound than if you engaged the kickstarter while running. It sounded less "clanky" and more "vibrating/grinding" if that makes sense. Grabbing the kickstarter and moving it didn't help the issue.
      When I noticed it, I shut the bike off and gave it a second. Being a few miles deep into the dunes, I had to get it out of there so I started it back up and it seemed fine- no grinding. I headed back to the car and after a few minutes, it came back so I shut it off again, started it back up and nothing. That process happened one or two more times before I made it back to the truck. Seemed to run fine otherwise.
      Once I got it back to the truck I started it up and tried to pay more attention to what was going on but it wasn't doing it. I did seem to have more of a metal on metal noise coming from the motor. I started and stopped the bike a few times and after the motor stopped there was a distinct metal clank/grinding noise that happened right after the motor shut of for maybe half a second. This doesn't happen every time.
      I tried doing some research and have seen things that make me think it could be the spring that connects to the kickstarter, or the kickstarter stopper plate- but really I have no idea.
      Seems strange that the issue is off and on.
      Thanks for the help!
    • By Goof331
      Does anyone know if there is any differences between the 2 radiators? Will the yz450fx radiator bolt on a yz450f? What I am wanting to do is wire up a fan to my 2016 yz450f. I know how I am going to do it I just don’t want to use a “universal” fan kit. What I would like to do is get a 450fx radiator and the direct bolt on Trail Tech fan for that radiator to have a good clean look.
