Speedo trouble
Have any of you guys had trouble with the electric speedo? I have just had to send mine away today as it went all spazy, keeped changing modes and then just stopped working. anybody else had this trouble???? :)
For whats its worth I have a Australian/Euro KTM450 and my electronic odo will not allow me to adjust the wheel size, for fine tuning the odometer. Its set at 2250 and cannot be changed, I know I'm using the right routine because I was able to change the wheel size on an American/Canadian model. Go figure? Anyone else having difficulties.
I took mine straight off and put it on a shelf! But I know of one other on 525 that has the display go blank whenever it feels like it. The tripmeter does keep working in the background, but you cant see it most of the time.
The Aust version is hard wired for batt and thus has no battery installed, if you disconnect the r/br/bl 3 wire connector and put in a battery (number is on back of speedo)it will then allow you to change wheel size. Near as I can figure its a legal thing having a streetable bike that you can alter the speed reading on. I spend best part of a day researching this, as I thought my unit was defective. I even left the battery in so if I want to calibrate for a different tire height, for accuracy I only have to unplug the power connector and run on the battery. Hope this will be of some assistance.
Glad you found your answer, katoum. Thanks for sharing the fix.
I've had my trip2 odo, which is what I use for my main display, reset itself 2 or 3 times. Kind of frustrating as I like to use that for oil change intervals. The hour meter always works so I guess I'll just have to start going by that.
My speedo came set with 2250 wheel size. Is that the correct outside diameter for 21" wheel?
Hey Katoum,
I don't understand why you need to use a battery. Can't you just disconnect the unit, then reconnect and reset the wheel size? Surely the bike can't tell the computer what wheel size to use? Just curious.
Wheel size varies between models. I put a mark on the floor of the garage and on the tire. When the mark comes around again as you push the bike, mark that spot on the floor, too. Then measure that distance and set it into your computer.
Throw that all out the window at an enduro, though. What's critical is getting your odo sync'd up to the odo used to lay out the course. You generally do that in the first few miles at the course markers.
Yes, that's the default, its close but does not give pinpoint accuracy due to different tire heights.
Thanks for the info. Slowly getting used to this gadget and no mysterious problems with it yet.
Fremont. No, I dont think thats right unless im missing something with u.s. spec compared to u.k.
The wheel circumference for the 400,450,525 exc with the standard enduro tires is 2205mm and this is the setting you want for your new speedo.
You should be able to convert between kmh or mph automatically by using the menu.
If you want to be 100% accurate make sure your front tire is inflated to the correct pressure that you ride and with the bike standing upright on a solid floor, measure from the floor to the highest point of the tire and take the height in mm. For KMH it is your measurement x 3.14.
For MPH it is the same measurement again in mm x 3.14 then divide by 1.61.
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
