WHATS THE DIFFRENCE IN REAR LINKAGE FROM 02 TO 03?
I FOUND OUT IN MY PREVIOUS POST THAT THE T-CLAMPS ARE THE SAME FROM 02 TO 03 AND THE DIFFRENCE IS IN THE REAR LINKAGE. WHICH PART EXACTLY IS DIFFRENT AND HOW DOES THAT MAKE THE 03 TURN BETTER THAN THE 02?
my guess is they just changed the length of the pull rods to raise the rear and created a steeper head angle.my .02 worth.
Both the u shaped pull rod and the delta link,that is the piece that the shock bolts to are slightly different in dimension.
they changed it by 7mm. to make for better turning.
