DRZ400 rebuild/supermoto treatment
Hello all, new here.
I've just acquired a DRZ-S which was an insurance write-off. It's been cosmetically wrecked by the kids who stole it and the wiring is completely shot. But engine, frame, suspension and wheels look fine.
My plan is to rebuild it as cheap as poss (eg only using genuine Suzuki parts where necessary), then give it the Supermoto treatment.
Here's a list of the parts (below) that are shagged/missing - if anyone has secondhand items for sale (and is in the Midlands, UK!) then get in touch to sean_warwick@hotmail.com
Otherwise I'd be interested to hear the experience of anyone who has supermoto'd their DRZ - what parts you used; did they bolt straight on? Were they good value etc.
Model: Suzuki DRZ400-S
Year: 2000
Colour: Blue
Top yoke stanchion clamp bolts + washers x 2
Mirrors
Left hand switchgear set
Right hand switchgear set
Complete wiring loom
Ignition barrel + set of keys
Air filter box cover (if there is one)
Battery housing/mounting + fixings
Battery
Battery earth lead
Workshop manual
Left hand engine cover + gasket
Neutral sensor(?) (eg thing on lh side bottom of engine near gear lever with 3 wires coming out of it!)
Radiator sensors(?) x 2 (eg things that screw into top of rads, with wires coming out of them!)
Pillion footrests + fixings (probably won’t bother)
Speedo cable
Speedo drive cable retaining bolt
Complete instruments assembly
Fuel tank + fixings
Fuel filler cap and breather
Radiator shrouds + fixings
Brake lever
Clutch lever
All side panels + fixings
Air filter (and cage, if there is one)
Full set indicators + fixings
Complete front headlight assembly + fixings
Complete rear light assembly/ reg plate holder + fixings
Or is this an overambitious project?!
All comments welcome
Argh!!! He done it again :)
That photo should have a warning attached before it fills the screen :D
I think it sounds like an easy project.
Pick up a dualsport kit (bajadesigns or elecrixUSA) $400. USD
The other goodies are bolt on , many are aftermarket. What did you pay for it? How much is a new one for comparison?
Its value as a write off is probably about £2000, and they cost about £4500 new over here.
Any Brit-based posters here who would recommend suppliers they've used either UK-based or got stuff from abroad, off the net?
Hi there sean and welcome to TT.
I live in Belfast N. Ireland and i recently aquirred an exhaust insert off an English guy in Germany. About 2 months ago he had a 2001 S competely stripped down and nearly all the parts were for sale. Give him a shout. He uses the yahoo european DRZ group. Hopefully he will be able to sort you out with allot of the stuff you are after. His email is symonds@web.de Say Gary sent you. Good luck
