2003 450 exc (Canadian)
Can someone explain what the term "restricted" means? I just purchased a new 2003 450exc and was wondering if there is something that needs to be removed or changed.
I was thinking the same thing... in my manual it mentions a throttle stop... which the MXC & SX versions don`t have.
Do we have to grind it like they do on the Yamaha WR`s ???
I think that it is refering to the jetting being so lean. Resticted intake for California emissions
So the burning question is: Do I need to do anything to my bike other then change the needle out with the one that came in the kit? BTW this is also the same needle that the manual has stated. I put the clip in the same position. Will the bike run okay?
The resrticted models are actually Australian spec bikes. There are a few floating around in Canada. I think most of them have gone to the US though. The "restricted" bikes have a throttle stop like the US WRs have and a screen in the muffler that needs to be removed to achieve max hp. They are jetted even leaner than the "G" models, if that is possible, from what I understand also.
So how do I figure out if my bike has the throttle stop and screen in the muffler?
Pull the carb off and look at the slip with the throttle WFO. If it's not open to the top you have a T stop and if you have one you more than likely have the other.
Did the bike come with signals and all the dual sport stuff? If it didnt, your bike is NOT the restricted models. CDN spec bikes are exactly the same as the bikes you guys get in the USA.
Hope I can clarify some misconceptions out there on the Can Model. It is exactly the same as the American model. That being said there are a few Aussie/Euro model, floating around Canada, and I was fortunate to get one.
The difference is the Australian version comes with full signals, horn, high/low beam, indicators, mirrors, and front and back break lights, and a different sub fender to accomodate the larger tail light.
The restrictors on carb are totally different than YZWR models. The 03 carb is a new model FCR and the throttle stop is inside the slide, it only allows the slide to move 1/4 throttle, limiting RPM to about 3800. The air box has a shroud and baffle which completely covers the filter. The exhaust has a wire mess screen spark arrester visable in the muffler.
The bike also comes with a replacement needle which is the same as the off road version. The air box baffle is removable, and the screen can be cut out if you wish. With all the restrictors in place the bike is 82 db. This was obviouse done to make some legislators happy, but it can all be changed in a hour or so. Hope this answered some questions on the Canadian version.
So I waqs also fortunate to get the Aussie model - is it restricted too? I did not see any covers on the air filter box, did not see a screen unless it is way inside the exchaust and by turning the throttle it seems that it opens all the way up. It did come with another needle which I have replaced. So what is up?
  • Similar Content
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
    • By Brawg
      SO, for information sake and to power the search engines with some key words that i couldn't seem to trigger during my research...I'm posting my desmog process on my new 500exc. Being a new bike...i wanted to make sure that all of my "doings" were going to keep the short excuse for a warranty in tact. I have part numbers for the plugs, washers etc as well as what all came off of the bike. I know it's a simple process for some, not so for others and would like to give credit to the advrider.com writeup for some great info.
      Long story short...i plugged the hole left from the smog pump thingy on the right side of the cylinder, the Secondary Air System (SAS), the overflow canister, and all the hoses/wires that go with. The electrical plug that was involved I simply taped up with grease in it and strapped it to the inside of the frame rail.
      After i took all of it off, it would not idle....i turned up the idle adjuster (to the left) or counter clockwise in order to increase the idle speed.
      Result!!!!!! NO popping on decal, no stalling after hard accelerating, etc. Sometimes after much creeping and low rpm riding it will load up and flame out. I plan to try a different map after i install my exhaust. I think a new map will be able to add some rev to the top end. Right now it seems kind've flat once you pull through the sweet bottom and mid ranges. The bottom end power of this bike coupled with the silky smooth clutch action makes for the easiest and best suited off road bike i've ever been on. It does what i need it to do!
