why do i have to login everytime??
ever since this new forum was put up, im having to log in every time i go to this site. i dont mind it too much but its not like it used to be. ive looked over my IE settings and everything seems to be working out fine... is there something im missing?? im apart of another forum also that uses this same "infopop" style of forums and the problem isnt happening. can somebody help me out here. but hey, i cant complain... i paid off my bike yesterday... its all MINE now! :)
Do you clear out your cookies every day?
i bookmarked the main page and i never have to log in unless i log out.
no, i dont delete my cookies everyday. i might delete them once a month to clean things up a bit, and ive also got this site saved on my favorites, but still not working. I'm :)
I had the same problem. I fixed it by logging in and then going to the DRZ page and book marking it. I haven't had to log in agian. Good luck
I had the same problem. I fixed it by logging in and then going to the DRZ page and book marking it. I haven't had to log in again. Good luck
did you check the box on your IE sign in page to save your password? If you initially said no, you may need to mark it now.
  • Similar Content
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
    • By Markl5557
      Anyone’s air box smell like gas ? Is this normal ? Air filter is bone dry but it reeks in there .... I’m assuming cause of the carb being semi filled with gas ??
    • By Markl5557
      So I’m reading these horror stories of the stock vacume operated petcocks failing and letting gas into the oil .... how many of you guys switched over and is it worth it to switch to manual ?
    • By Markl5557
      Hey guys . I feel like I post here way to much lol
      anyway after having my bike kn it’s side overnight to fix a cracked stator cover .... I come to find out that I also accidentally left the pet cock in the prime position .... constant gas flow to carb ... now my oil smells strongly of gas ... my question is ... was it the bike being on its side that made the gas get into the oil or the prime position on petcock that made this happen ? Or both ? I didn’t ride it much at all after discovering... I assume. I should drain the oil obviously but any other suggestions ? Always appreciated -mark
    • By Praneeth143
      Hello guys , I have a suzuki drz400sm which is a 2009 model recently I purchased a rear sprocket which was a JT 41T , but I found that it did not fit to the rear sprocket hub of the bike and my drz has got the EXCEL TAKASAGO rims in it . How can I find one that fits and what sprocket brands and where can I buy it . I have attached pics of the current setup , please help me
