DRZ400S Supermoto project - any advice?
Hello all, new here.
I've just acquired a DRZ-S which was an insurance write-off. It's been cosmetically wrecked by the kids who stole it and the wiring is completely shot. But engine, frame, suspension and wheels look fine.
My plan is to rebuild it as cheap as poss (eg only using genuine Suzuki parts where necessary), then give it the Supermoto treatment.
Here's a list of the parts (below) that are shagged/missing - if anyone has secondhand items for sale (and is in the Midlands, UK!) then get in touch to sean_warwick@hotmail.com
Otherwise I'd be interested to hear the experience of anyone who has supermoto'd their DRZ - what parts you used; did they bolt straight on? Were they good value etc.
Model: Suzuki DRZ400-S
Year: 2000
Colour: Blue
Top yoke stanchion clamp bolts + washers x 2
Left hand switchgear set
Right hand switchgear set
Complete wiring loom
Ignition barrel + set of keys
Air filter box cover (if there is one)
Battery housing/mounting + fixings
Battery earth lead
Workshop manual
Left hand engine cover + gasket
Neutral sensor(?) (eg thing on lh side bottom of engine near gear lever with 3 wires coming out of it!)
Radiator sensors(?) x 2 (eg things that screw into top of rads, with wires coming out of them!)
Pillion footrests + fixings (probably won’t bother)
Speedo cable
Speedo drive cable retaining bolt
Complete instruments assembly
Fuel tank + fixings
Fuel filler cap and breather
Radiator shrouds + fixings
Brake lever
Clutch lever
All side panels + fixings
Air filter (and cage, if there is one)
Full set indicators + fixings
Complete front headlight assembly + fixings
Complete rear light assembly/ reg plate holder + fixings
Or is this an overambitious project?!
All comments welcome
Wow, it looks like you have some work ahead of you. :D
I think it would be a fun winter project, and you should be able to find several DRZ supermoto guys for advice. Send me an email vrecksler@hotmail.com with some questions and I will let you know what I have done with mine. :)
Got any pictures of that thing?
It must have been cheap!
If you're going to use your standard caliper with a 320mm disc, you'll need a relocation bracket.
I've got one for sale. It's gold anodized and like new.
I'm asking $50 AUD which is around $25 US.
Good luck with your project.
Mike. :)
