Best way to take graphics off
What is the best way to peel the stickers off the bike? Do you heat them up or any other tricks to get the graphics off.
I use a heat gun but a good hair dryer should work. There is still residue left sometimes and requires a solvent to remove.
hair dryer works for me. it's also useful in putting them on.
I also use a hair dryer. A heat gun can be dangerous. Also to put the new graphics on heat them up with a hair dryer and spray plenty of windex. This way you can lift and move them until they are straight. Then squeegy the windex and bubbles out.
Excellent tips. Thanks. The windex idea is killer.
I used the windex to position all my graphics on my various hobby objects and never had aproblem until i did a pair of N-Style Graphics on the shouds. The windex seem to take away some of the adhesive strenght from the sticker. be carefull with that.
Heat and a gentle touch...pull slow and steady...it gives the glue a chance to release.
I use the Windex trick as well....with a twist. I run my hand over the area I've sprayed to help pop all the little bubbles in the Windex. I know it sounds crazy but it cuts way down on the bubbles you have to work out from under the graphic!
I also found an easy way to heat new graphics up before working with them...put them on top of the dryer! It's flat and not TOO hot. :)
I just pull the sucker off and use some brake cleaner to get the rest of the residue off.
Anybody tried just using water with a drop of dishwashing liquid? My cousin puts decals on his company's new trucks every year and that is what he uses. I tried it on some small decals and it seemed to work okay. I think windex has ammonia in it and that is probably hard on the adhesive.
talked to n-style today, said nix on the windex, it will harm the adhesive. just be patient and use a hair dryer!
03 450f adding goodies daily
By far, the best method of taking them off that I have seen is using my pressure washer. It never fails that I always remove graphics with it! It takes them right off.
  • Similar Content
    • By GarrettSG
      I need recommendations on Honda dealers with good Mechanics in Western Washington. I am in Puyallup but will drive for peace of mind. I have never had a dealer do major work on any of my dirt bikes. But long story short I am on a 15 CRF450R and it needs the 5th gear recall done. Any and all info is much appreciated!
    • By jakebarritt
      I have a 2005 CRF450R with a Trail Tech fan kit installed. I need a little bit larger tank and would like to know if anyone has an aftermarket tank that fits with the fan kit.
      I dont need a monster 4 gallon, just maybe a 2.4 or 2.7 from IMS would do fine.  I talked with both the tank vendor and Trail Tech and neither could give me any answers.
      Thanks guys.
      Jake
      Minden, NV
    • By NickC18
      So I emailed Factory Connection today to see what spring rate I need for the rear as I’m about 6’2” 220 lbs without gear. I also asked for a baseline front fork PSI to start at. This is what I received:
      Nicholas,
      The spring series we made for your bike is limited when it comes to larger/stiffer rates.
      The spring rate you need is 5.9/6.0 range. We don’t sell that over the counter as it requires special installation process.  So we can’t sell the spring “over the counter”.  It would have to be installed at our shop.
      Fork PSI I would recommend:
      Inner 160 psi
      Outer 11 psi
      Balance 160 psi
      Are they blowing smoke up my ass? What kind of ‘special installation’ could a spring take? I’ve changed and removed them before but not on a 16’ CRF before.
      Also, aren’t those psi settings for the Kawasaki KYB? I don’t think the psf2 have inner/outer/balance do they? Maybe he was having a bad day...or maybe I’m an idiot. FC’s website list there spring as ALS-0059. Can I not just order this spring and install it to set my sag correctly? Help?
    • By johnsbikerepairs
      hi, i have a crf450R 2009, having difficulty setting the idle knob to factory setting.  Having problems interpreting manual Japaneses interpretation.  Can anyone out there assist with the correct factory setting and how i can manually do the setting ie how many clicks out or in etc...   would appreciate any assistance
    • By Baja Designs
      Hello CRF450R Owners,
      Bailey here with Baja Designs.  We recognize ThumperTalk as one of the go-to sources for information on the CRF450R and we receive emails daily regarding the best inexpensive light setup or purchasing the B1K setup ran by Ox Motorsports.  We would like this thread to be a General Discussion area for members and guests to discuss Dual Sport Kits (DSK), Lights, and Lighting Acessories based upon stock and modified charging systems.  Please Post up if you have any questions or comments CRF450R related!
      www.bajadesigns.com
