Cam Chain Tensioner
Fellow TT'ers. I'm going to share my mistake for all to learn from. I value all the great info on TT and appreciate lessons learned from others so now it's my turn to share my embarassment (I mean my lesson!).
When it comes time to remove the cam to adjust valves, per the manual, you must install a small screwdriver into the cam chain tensioner and rotate clockwise to remove the tension off the cam chain then hold the screwdriver there because it is spring loaded (Antman's zip tie to the frame works great). When you've completed your shim work and it's time to allow the cam chain tensioner to resume its job, simply pull the screwdriver out, allowing the spring to recoil the tensioner back to the "tight" position. This is how it's supposed to happen.
Here's where my learning comes in....When you first start to remove the tension only turn it clockwise a turn or two, just enough to remove the tension, you'll be able to see the chain go slack off the cam sprocket. DO NOT TURN PAST THE RESISTANCE YOU'LL FEEL after about two turns. Furthermore, don't reach in with your screwdriver after you've released it and turn it counter-clockwise to 'verify' that its all the way in! I believe this was my downfall as it deformed the spring enough to slightly jam it which led to it comming loose and the chain jumping a few teeth which, of course, led to Mr. Intakes playing patty-cake with Mr. Piston. What's worse is it happened at one of the many times I was in the process of kicking PatD's ass! Result: bent valves ($65 ea.), ruided cam chain tensioner ($50), and, most importantly, a painful DNF loss to PatD (priceless!).
Don't be intimiated by this simple procedure! Just don't go beyond the mechanism's limits as I did. It's just a recoil spring (like a lawnmower's pull starter) and is easily tweeked. I took mine all apart to study it and it's quite difficult to assemble back together correctly once the spring is deformed. This must be the reason you can't just order a $2 spring, you have to get the assembly ($50).
Hope someone can take advantage of this!!!! :)
For $5 you can buy the tool that the manual suggests you build.With this tool, I doubt you can damage the spring. I bought one and it works great.Amazingly small, but effective. You can see the ad for the tool in
I took my tensioner completely out with the two 8mm bolts that hold it in. Then, with the tensioner in my hand screwed the srping back and held it place with the tool or screwdriver then bolted it back up. No problem whatsoever!
yeah... i couldnt find in the manual anywhere explaining how to setup the tensioner. i've been running it a little tighter then how it sits naturally. I'll reset it to its now i've read this :worthy: (reset = turn anticlockwise and release until it rests with its own tension) - this is correct, yes?
there is no set-up to an auto tensioner.......get a manual's have failed on 02-03 bikes.......btw this thread is 5 years luck mate
is resetting the stock tensioner as easy as turning the bolt in the middle clockwise until it stops and then releasing it? do i have to be at TDC?
it has to be rewound and then mounted.......then let go of the flatblade.......tdc? no
I have to take the thing off?
no get a tool..........go to ebay and type in crf450 cam chain tensioner....10 bucks......02-03 tensioners are the same.........04 on up are different
  • Similar Content
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By desert520sx
      I have a 03 450 that I just got and it runs great! I love my bike and am big on preventative maintenance. I have searched the threads on TT and have not found any descriptive threads on how to check valve clearance or adjust them. Just by looking at them, I can see that the intakes need to be shimmed and the exhaust valves can be adjusted quite easily unless one needs to be adjusted differently than the other.
      I tried to do it last night, and lined up the marks on each side to get the piston to TDC to check adjustments and could not get any readings on tolerances on either the intake nor the exhaust. I moved the crank a little bit forward and got a .011 reading on the exhaust valves. I read in a thread that the spec was .011" for the left one and .014" in the right for the auto decompressor. The spec I am using for the intakes is .006" Are these specs correct? :excuseme:The only issue is that the adjustment for the exhaust valves is one and the same. Different from my KTM where you can adjust each valve individually.
      No matter where the cam was on the intake valves, I could not get any readings. Does anyone have a thread, website, downloadable manual, or article on checking and adjusting valves in these beasts?
    • By Eric Schrader
      I am selling my 2007 Honda CRF 450-R which is set up for desert racing (Track/desert). It has an 18" rear tire with a heavy duty setup (see description for details). The bike screams and has a Tokyo mods carb mod with the 10x ignition mapping (currently set to a handlebar switch for smooth power and max power). Gas tank is a 3.2 gallon IMS dry break tank. V4 steering stabilizer included. Precision Concepts suspention, Bike is set up for 6'4" 175lb rider. Zero oil leaks and well maintained using a preventative maintenance method with the best new parts each time. Receipts for all items can be provided. About 20 hours on the rebuilt head. Carb just rebuilt. Starts cold in just 2-3 kicks. 100% reliable bike as long as you turn the gas on.  Current CA Red sticker and original title.
      Expand above to see details
    • By bigg_stevee
      I recently replaced water pump and seal after I noticed that my '02 CRF450R was spilling coolant on easy trail rides. After the water pump swap (which was successful), I noticed the same problem. It's interesting - the bike only spits coolant (I mean a LOT of coolant) after passing anything above 1/2 throttle. The bike makes this weird 'gurgling' noise, like trying to suck through a straw when your glass is almost empty. This is weird because I properly bled/ burped the radiators with coolant, and filled them to normal operating levels. The coolant spills through overflow hose.
      anyways - I swapped the radiator because I thought maybe the bike was running hot. I purchased oversized radiators, bought a 1.6 radiator cap (with a temp gauge) and bought engine ice. The bike runs very very cool - the temp gauge allows me to see this. Still, the bike shoots coolant out of the overflow after going above half throttle, making the same weird gurgling noise when it does. Bike has all of its power, top end was replaced not too long ago.
      I'm lost and don't know what is wrong with the cooling system in my bike. How do I make the bike stop shooting out coolant, and stop making the weird gurgle noise??? Any advice would help me!!! Thank you!
    • By Mxer59
      I have a brand new Barnett Extra plate setup still in the box. It replaces the judder spring with a regular fiber. My old clutch had a judder spring break which wiped out the stock clutch. I was in a bind ordered this kit but it ended up coming 2 days later then it was suppose too. So now I don’t need it asking $180 SHIPPED
      —“Complete Extra Plate Kit- consists of 8 Kevlar friction plates, 7 tempered steel plates and a set of springs. Provides maximum clutch capacity.”—
