What are the best Hand-Guards
I don't want to run the risk of shattering my beloved fingers on a cedar in 3rd gear, so what are good ones? I have heard a couple people talking about the acerbis rally pro. Anyone tried these? Also, where can I get them?
I run MSR aluminum on my WR400. My wife and daughter have the rally guards(with the aluminum inside the plastic) on their bikes. Both are quality, MSR a little less flash and cash. Both setups fit great.
Check out the new "Wacker" hand guards by Motonation. They are pretty nice units.
Buy some aluminum bark busters, several manufactures (I like Moose). The bark busters themselves are just metal. If you want the plastic end guards, then they are here: http://www.motorcycle-superstore.com/item.asp?style=2623&department=656&Division=6
They also offer radiator protection by not bending your handlebars so easily. $40 - $50, should be available at your local shop or wherever you wish.
Don't worry, your hands will be fine (wear GOOD gloves, like Fox), no need for the funny looking plastic things if you don't want to, but BUY a set of bark busters. Have fun! :)
I use Acerbis Rally II guards. These have less strength than the version with aluminum but still offer good protection. Advantages are that they are lighter and less rigid - allowing the handlebars to flex as they are designed and in theory, reducing fatigue.
Rocky Mountian ATV-MC has good prices and service.
web page
Rally pro with aluminum inside are a good choice. Baja designs sells the replacements for $38-40 after you scrape em up after a couple years. I like them because they help your bars slide along the ground instead of digging in as someone else pointed out on another post.
I have used Acerbis Rally Pro, SRC, and Cycra Pro-Bend handguards. I like the Cycra's best for a couple of reasons.
1. The bend on the guard allows better lever movement, especially if you crash.
2. The triple-clamp mounting gives the bars more stability, and frees up more bar space for goodies like computers, roll charts, etc. This is especially important if you cut down your bars.
All of the guards I have used are strong, but the Cycra's edge out the competition in my book. I now have them on both my YZ250F and my XR400.
Hi Toy Hauler,
Will the Cycra's mount to rear facing pinch bolts on the triple clamp? I'm using Applieds and it bolts are on the back. I wished they were up front.
The Acerbis Rally Pro fit poorly to my Renthal fat bars even with the adapter kit (in my opinion). It could have been much more sano. I used longer allen head bolts and it works OK.
Thank you!
Just about every large motorcycle shop sells handguards.
Rally Pro Handguards - Metal re-inforced, on my XR400
Rally Brush Handguards - All plastic, on my XR200
Rally 2 - New, looks interesting
Some riders have plastic Acerbis copies that they like. One thing I do like about the all plastic Acerbis handguards is they are a bit more square and the levers fit easily.
The metal re-inforced Rally Pro seem very stout, but have a more rounded bend, so the lever end clearance is tighter. After a good crash, the clearance can be lessened. Make sure you are not catching the clutch lever end after a crash. The easier way to straighten them out is to unbolt the handguard at the inner mount. (1 bolt) Bend it out at the bar end, bend square at the corner. Bolt back on. I have never had the throttle stick after a crash.
Both handguards are wide where they meet the end of the handlebars. This allows the handlebars to slide and not dig in when you crash. My XR400 has slowly slid for 15 feet on steep hills.
I cut the grip on the clutch side by lightly taping the bar ends with a hammer. I cut the throttle grip on the inside of the outer rib with a knife. After you remove the stock hanguards, you will need a stack of washers or a shorter bolt on the clutch side.
If you get the Rally Pro, use low strength Locktite on the bolts. They tend to loosen up. However, you do need to loosen and adjust them at time.s
I have the Acerbis Rallys (all plastic, no metal) on Hebo bars. They have been tested unfortunately, but saved my hand. While ripping through tight hare scramble trails, I was going too fast and clipped a tree with my right knee and handlebar. It stopped me right now. I remember feeling the hand guard snug up against my knuckles a bit, but didn't hurt. What hurt was my knee. I had a bloody knee but my hand was fine. I like 'em. :) Now I need knee guards...
Do the Cycra's have the metal insert? Are they durable? I like the price.
Also, what do people think about the Factory909 brand? Are they any good?
I think $90.00 for the factory 909 handguards is excessive.
Had the Acerbis Brush Guards (no metal insert) and liked them because of the light weight, however when exercized, they flexed enough to allow the clutch lever to bend. Any hard fall to the left always resulted in a bend in the end of the clutch lever. Switched to the Wackers and so far so good. The metal insert can absorb, through deformation, a lot more energy that the plastic. They bend back more easily that the levers.
all the good handguards were too exspensive so i came up with a better solution.instead of motorcycle gloves i wear 8oz. boxing gloves when i ride they work great.the best part is you dont hurt your hand on buddy's helmet if you have to slug him when he's trying to pass
I think I like either the cycra (cause they are cheap), Acerbis rally pro (everybody has 'em, so they can't be taht bad), or the moose (cause they have the replaceable outer part). However, I can't find the metal inner part for the moose. Anybody have a link?
Check the product again. Some handguards are meant to mount on bark-busters.
On groups.yahoo.com someone posted about an Acerbis knockoff that was cheaper and better. It's under the HondaXR or XR400 group. Or maybe it's here.
From Don...
I don't know or remember where I got this tip but it worked great. I just installed a set of Acerbis Rally Pro hand guards. When you remove the stock hand guards you are left with the front brake lever pivot bolt that sticks up alot. You can order from Honda part # 90114-166-006. Its a pivot bolt from some late model CR models that threads all the way down. Also get part # 53176-ML3-791, it's a brake lever rubber boot. Both of these will set you back about $9.00 and they fit perfect. Thanks to whoever figured this out.
Where Can I get the Barkbusters? Is Barkbusters a brand, or type of something?
What about the Maier Aluminum handguards? Are they any good? Here is a pic:
I use the Acerbis Rally Pros,indestructable. All my KTM friends use the E-Line,and several have had trouble with the bolts tearing through the palstic. :D :D :):D :D
  • Similar Content
    • By Kev_XR
      If you own an XR250, many of these tips will apply, however, the carburator jet sizes will be different.
      It really helps others answer your questions.
      I will fix them as time allows.
      Until then the Search Feature and enter "kevin's xr400 mods".
      The results will bring up most of the links.
      Here are some frequently asked questions I have answered before.
      Which XR should I buy?
      The longer the straights, the taller the hills, the deeper the sand; the bigger XR you want. The tighter the trail, the smaller hills, firmer terrain; the smaller XR you want.
      The XR400 has a great motor that will pull you almost anywhere. You can be sloppy on a hill climb on an XR400, where you have to keep the 250 singing. The XR400 weight is most noticable when you drop it or try to stop it going down a long downhill. (Moooomentum!)
      The XR250 feels like a mtn bike compared to the XR400. My friend rode his XR250 for years before decided he needed more power. Even then you can add a 300 kit and get good power.
      If you were heading to ride fireroads in Baja, I'd tell you to get the 600/650.
      To the tight woods, get the 250.
      A lot of both, the 400.
      Dual-sporting? Go bigger for more freeway, but don't show up at the trailhead with too big of a bike.
      All of the XR's are great. Pick the one that fits your needs.
      Gordon's Mods for XR400 (Uncorking the bottle up performance)
      XR400 History
      The changes to the XR400 have been listed here several times. This list appears to be complete.
      In addition, HairyScary discusses how to tell if a part has been updated by the part number. Good tip!
      XR400 history
      Getting the Spark plug out
      It seems the MotionPro spark plug socket does not work on the XR400R, but works on the XR250R.
      There is an OEM tool kit being sold on eBay that seems to work.
      717448 XR400 oil change
      Here is a way to make changing the oil much cleaner.
      This tips is really handy if you have a skid plate.
      XR400 oil change
      XR400 FAQ by Paul Gortmaker
      Paul usually has very good info.
      Small bolts
      BE CAREFULL with the bolts on the oil filter cover!
      An oil covered bolt will not torque at the same rate as a dry bolt.
      The friction doesn't build up, the force simply builds until the threads strip.
      This is the reason many people strip out these bolts.
      Here is an execllent website on bolts, oil, and misc values.
      Did you ever wonder why a 8mm box wrench is half as long as a 18mm box wrench?
      It is shorter as most 8mm bolts cannot take very much torque.
      I highly recommend getting getting an 1/4" socket set.
      I bought the Craftsman set at Orchard (owned by Sears), which tends to sell them for less.
      What is the Snorkle?
      This place has a description and pic, it's easy after you pull the seat. I siliconed a piece of coarse screen (fiberglass) over mine to keep bugs and stuff out. - NORTEXT
      717439 XR400/250 Pre-Filter
      After pulling the snorkle, there is a big hole on the top of your XR400. My friend showed me this prefilter trick.
      767409 XR400 Engine Bog, Pilot jet, and the Fuel Screw
      On XR400's twisting the throttle from fully closed to wide open will cause the engine to "bog" or in some cases die.
      831305 Valve adjustment (Am I retarded...)
      Inspect and adjust valve clearance while the engine is cold (35C, 95F).
      Valve adjustment
      389095 bigger jets (Lists stock jet sizes.)
      96-97 XR400's were jetted assuming you would remove the intake and exhaust snorkel.
      98 and later XR's were jetted assuming you would leave them in.
      bigger jets
      739907 Cheap Tool for Setting the Fork Oil Height
      There are some really nice tools out there for doing this job.
      This tool costs $4.49 at Kragen.
      Cheap Tool
      392932 high altitude jetting
      There are two big factors for jetting, elevation and temperature.
      Allen screws for the XR400 carb
      This lists the screws you need to convert the XR400 carb to use allen screws.
      Allen screws
      Screws for the brake and clutch after removing the stock handguards
      TBD - There is a post with the shorter screw part numbers for after the stock handguards are removed. Use search.
      Very quick engine hop up
      This is a very minimal change that should take less than an hour.
      Most of that time is removing the float bowl (3 screws).
      If you decide to do the full "Gordon's Mods" later, you will need to replace the jets again.
      o Pull the intake snorkle.
      o Add a UniFilter.
      o Pilot jet to 55, main jet to 155. (Assuming sea level and moderate air temps.)
      Source: Motocross Action magazine.
      Quick engine hop up
      Gordon's mods
      Baja Designs Baja Baffle with 96' spark arrestor.
      Pull the intake snorkle, UniFilter, 60 pilot jet, 162 main jet.
      (Depending on altitude and temp.)
      What to add to a new XR400 or XR250?
      Acerbis wrap around style handguards (saves levers and bars as they don't dig in)
      Baja Designs skid plate (Made by Utah Sports Cycle)
      Acerbis fork/disc protector
      Grease headset and rear linkage
      Spend you money on the suspension, not a pipe!
      First get some stiffer fork springs (96-97, 98-99 years)
      Fork revalve (cost: 2 qts of oil & time)
      Shock revalve (cost: oil, nitrogen, shim stack, friend who knows shocks)
      Jetting for Altitude (XR400)
      Assuming at sea level and 68 degrees, you would use a 60 pilot and 162 main.
      At 5000 feet and 68 degrees.
      Jettting correction:
      Main 0.96 * 162 = 155 -> 155 main
      Pilot 0.92 * 60 = 50.6 -> 55 pilot
      Due to your elevation, you have less air and less fuel.
      Your bike will not behave the same as a bike at sealevel.
      First, check the fuel screw. If it does not affect the idle speed, you have the wrong one.
      kevin's xr400 mods
    • By Child
      Can we make a sticky thread of pictures? I've done search for pics but I want to see all sorts of bikes just for ideas on stuff without having to go through tons of threads. Not trying to sound whiny or anything, but I think it would be nice to do what they do in the CRF250X forums with a sticky thread of just pics, no comments or anything. Think we can get one of those rolling here?
    • By kawamatt2
      Ok guys, add one more to the list of riders attempting the USD fork swap to an XR frame. Quite a bit of research here on TT and ebay hunting brought me a pretty good deal on a set of forks, triples, and stem from a 00' CR 250.
      There are a few different options for adapting CR style forks to an XR. Bushings for upper and lower CR triples can be made to allow use of the stock XR stem. Specialty bearings can also be purchased to allow use of the stock CR stem in the XR neck. And finally what seems to be the most common; modification of the stock CR stem to allow use of XR sized bearings.
      I obviously chose to pursue the third option for a few reasons, the most prominent of which is serviceability. I wanted to keep as many wear items at possible as stock parts. This has two advantages; availability and price of replacement parts. $45 dollar a pop "specialty" thin section tapered bearings don't sound too appealing especially when being used on a 12 year old dirtbike.
      So now we can get to the meat of the issue; modification of the CR stem. I should begin by saying that i am NOT a draftsman. I've taken a few classes on engineering measurements but am far from an expert and probably only mildly proficient reverse modeling components. With that said, the first order of business was comparing an XR stem and bearings to a CR stem and bearings. Shown below.
      A little closer look at the XR setup.
      And the CR setup.
      Now to get out the calipers and model up the stock CR piece. I used a cheaper set of calipers and suspect their tolerance is +/- .01mm. Good enough for gov'ment work though! All dimensions in millimeters.
      Now to modify the CR stem to work with the XR bearings while remaining compatible with CR triple trees. There are a few things to say about why i did some things the way i did but most of the thoughts are included in the notes section of the drawing.
      With a resized stem we run into the problem of mounting the top triple clamp. The hole is too large for the stem. An insert bushing must be made to resize the hole in the clamp.
      Finally what the stem and bushing look like together.
      Last one. The difference in how the top triple clamp is located on the stem. The CR is equipped with a chamfer that provides a stop for the tree while the XR's triple appears to be limited only by the threads for the castle nut.
      So... would like to hear your opinions on the execution of the stem modification and bushing. I think having these drawings will make it simpler to have the modifications performed as opposed to asking the machinist to completely reverse engineer the part him/herself.
      And a final query: Anyone know the thread callout for the two threaded portion of a stock XR steering stem? My drawings show the outside diameter of the threaded portions and i have a cheap plastic pitch gauge that tells me a pitch of 1.0 but i am looking for something more concrete than what i have.
      Thanks for your thoughts and opinions.
    • By ATJ_Number_1
      I'm on strike 2 here but thankfully this isn't baseball.
      The reasoning and my history. If you haven't figured it out yet I've done a crap load of work on these motors over the last 7 years but they have had 4 wheels around them. In the EX world there are a lot of carburetor options and although many are great there's a cheap alternative that runs 95% as hard as the high dollar options, some even liking it better then aftermarket. When I joined up here in the 2 wheel club I was shocked that the only accepted option was $400 for a 36mm Mikuni Pumper that isn't any bigger then stock! That cheap alternative for the EX is an 04-05 trx450r carb. It's 42mm round slide Kiehin piston-valve with accelerator pump and a mildly modded 400 loves it with a surprisingly strong bottom end yet. Yes I said 42mm!
      So as I build my XR4 I already know that I'd be shooting myself in the foot if I settled on a 36mm carb because I like bigger bores and cams and this motor likes bigger carbs. Makes sense, it is 400cc. Don't get me wrong though, the Mikuni is a real nice pumper for a stock bike and would seem fine on a well modded machine too but this 4 stroke is like every other one in the world in regards to when you go big inside, you want to go bigger outside or you're missing out.
      Whether the info is appreciated or scoffed at I'll post up my findings one by one as I try to find viable alternatives. When I say viable I mean still being able to use the stock environment and not needing a ton of work. I'm sure collectively this is not a new idea to search for such a beast but I enjoy a good project and I like cheap alternatives when they produce results.
      Currently the "test bike" is a 2000 Xr400r, snorkel removed, Uni filter, stock engine, stock headpipe and a 4" supertrapp slip-on with 11 discs.
    • By XL100allnightlong
      Just wondering if there is any tricks to polishing the stock headers on an 02 xr 400 to bring back the original copper color? If not ceramic coating them sounds like an option?
