My battery died but i got a cheap alternative !!
Wouldn't you know it.. 6 months after i bought my bike, the battery died.
I took it to the dealer like some of you guys did but they said that Suzuki Australia don't give warranties on batteries. :)
I didn't want to pay $200 AUD for a new one so i had a look around and i got this battery from a local electronics shop.
It was only $40 AUD which is about $20 US. This battery is the same size as the OEM battery and the same current rating but the terminals are different.
There's a company called Power-Sonic that makes a battery virtually the same.
I'll stick this battery in the bike tomorrow and if it starts, i'll be the happiest man on earth! :D
Here's a link to the electronics shop i bought it from:
Jaycar Electronics (Battery specs)
This link is the manufacturers website:
DiaMec Industrial Battery Co.
I'll post some results tomorrow.
Mike. :D
:) Update??
We use Power sonic batteries in all our emergency back up lights in our hallways at the apartment complex i run. My stock battery is still going strong, 1 yr 3 months old. Drained it down dead on my first ride of the year. Gas petcock was off! Gave it a bump start and it's been fine since.
G'Day Mike
I priced a batery at the dealers a few months back and I thought he said there were $100 AUD But also I now a bloke in the battery trade and he said he should be able to do it heeps cheaper :D . my battery is getting a bit slow if I don't ride it for a week,and I think the other DRZ in my shed is about to die also:mad:(the batttery that is)I think I might get him to give me a price tomrrow, I'LL let you know how I go;).I think that battery you got should be ok some of the guys from the states have used them with sucsess the only problem I know of with them is the conections.but I think some one drilled a small hole right through the spade terminal and battery post and fitted a small nut & bolt just as a precaution,just an idea.
IAN :)
PS Sorry about all the smileys I just learnt how to use them on our new computor :D
Well i charged the new battery yesterday and fitted it today.
This battery is excellent!
It cranks the starter motor as fast as the genuine battery.
If your battery needs replacing, buy one of these!
It's only 1/5 the price of the Suzuki battery.
To connect the DRZ battery cables to the new battery, i just got a length of 6mm twin and crimped a couple of ring terminals on one end and female spade terminals on the other. I had to pull all the padding out of the battery box to get it to fit because the insulation on the twin cable is quite thick.
I pulled out the little nuts and bolts from the Suzuki battery and used them to connect the ring terminals to the original battery connections.
I'm glad i found these batteries! :)
Mike. :D
Those spade terminals look awful thin and small. Do you think there might be a resistance problem there if you have to crank it for an extended period of time? Such as dumping the bike in some water or flooding it. I'd hate to see them glowing red :)
I think you would drain the battery before the terminals started glowing.
If the starter motor suddenly got stuck and wasn't turning and you still held the button on, it will probably start glowing because the energy has to be used somewhere.
If the starter motor cranks for an extended period, the energy is getting used up so it should be ok.
If it does start glowing, drop it back in the water. :)
It doesn't take long at all to make thin wire glow.....check out all those light bulbs around you :)
I've heared it before, someone recommended emergency exit ligth battery, and also someone said that cordless leafblower battery is the same as well, can't recall wich brand.
mine is 2 years old and going strong, 2000 DRZ-E.
You're right about the light globes but the terminals really aren't that thin. I think they're quite adequate for the job. I'll let you know a few months down the track how it's going.
Mike. :)
Does anyone have one of these batteries in their bike?
If so, for how long and have you had any problems?
Does anyone know how many amps the starter motor draws?
This battery seems plenty powerful enough for the job and i'm quite comfotable with it but i'll ask these questions just in case. :)
Mike. :D
The weak point will be the spade terminals clamping onto the battery spades.
The actual contact surface area allowing the current to pass from the battery spades to the spades on the wires will not be as much as the original setup. Less surface area for a given current to pass through equals increased resistance. For the short duration of cranking the motor till the engine fires up it shouldn't really be a problem. Extended cranking maybe another matter, can't say for sure.
What you really need to watch out for is corrosion/oxidisation at the spade terminals which further reduces the surface area able to conduct current. This applies to any electrical connector on the bike. Check and clean them occasionally and apply a contact grease to the terminals. The grease helps protect against oxidization and provides a bit more conductive area as the grease acts a bit like a semiconductor. Try an automotive electrician for suitable grease or I can let you know an electronics supplier who sells a spray can of contact grease (details are at home). For the electrical connectors not in the starter motor circuit a contact cleaner with lubricant is fine as these circuits do not draw anywhere near the current a starter motor does.
From a mechanical perspectve the battery spades may flex with all the bumps/vibrations of bike riding and break off. It might pay to look at additional fixings to eliminate this becoming a problem.
I would be concerned about charging current as well. I dont think the design of these batteries can tolerate much heat. I use them for starting my r/c helicopter. They are about $25 at the hobbie stores. Do a search on the net for r/c hobbies. Those spade terminals are not designed for high current loads/intermittent use. They are used for low current/extended time loads. I wired a pair of them in my daughters power wheels jeep when she was younger. They got pretty warm and lasted awhile but she had the fasted one around! :):D
I got a price off the battery guy I know and he told me $80.00 :D but it would take week to get one in :) so I ordered one for myself I'll just make sure it's the right one but he asures me it is its he said it is a yasua brand the one in my bike is a Japan storage battery co / GS brand whats in your bike .
Mine was a Yuasa YT7B-BS.
If it's the same thing, could you buy one for me and send it down dry?
Thanks Ian,
Mike. :)
Check your PM's Ian. :)
Mike. :D
G"Day Mike
Yeah no worries mate :) .I just want to make sure for myself that they are the same first he said they normaly retail for $145.00 but he would do me a special price :D :DI will let you know as soon as I get the first one ,I may need another one also just hope he doesn't mind doing a few :confused:at that price.
Thanks alot Ian.
Did you get my PM?
I sent it three times but it didn't show up as sent in "My Home" :)
Mike. :D
Yeah I got it all 3 times :)
That's funny because in "My Home" it still shows no sent messages. :D
Mike. :)
  • Similar Content
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
    • By drzvfr
      I did the fix last night and took some pics and notes to make this easy on people that haven't done it and want more detail. Please chime in if you think I've missed something.
      Required Tools:
      Set of Allen wrenches
      #3 Phillips screwdriver
      small flat head screwdriver
      8 & 10 mm sockets
      13 mm open end wrench (I needed this to remove my skid plate)
      snap ring pliers
      gasket scraper
      compressed air
      Required Parts:
      New clutch cover gasket, Suzuki Part # 11482-29F00
      Tube or can of RTV sealant
      Oil filter and oil (if you plan to change the oil)
      1. Remove your skid plate (if you have one). I have a Tonn's skid plate and it was in the way.
      2. Remove right side radiator cover.
      3. Unbolt the rear brake lever. This will require removing a cotter pin on the backside of the bolt, and then the bolt itself. I was able to swing the lever far enough out of the way without completely removing it from the bike (see pic).
      4. Drain the coolant. This requires removing the radiator cap and the small bolt on the water pump, which has an aluminum washer on it. I rocked the bike from side to side to get most of the coolant out of the bike.
      5. The oil, two options here. You can either drain the oil and remove the oil filter or you can do what I did which is lay the bike on its left side to keep the oil from pouring out of the engine when you remove the clutch cover. I still removed the oil filter so I could clean the clutch cover with brake clean after scraping the old gasket off.
      6. Loosen the hose clamp on the coolant hose that attaches to the top of the water pump and fold the hose out of the way.
      7. Remove the water pump cover and the clutch cover by removing the bolts holding them on. Note that some of the bolts are of different sizes so keep track of which hole you pulled them from. Also, not all of the bolts need be removed, see the pic below.
      8. Remove the old gasket from the clutch cover and/or the engine with your gasket scraper. I then cleaned the clutch cover with brake cleaner as it was fairly oily.
      9. With your snap ring pliers, remove the snap ring from the plastic gear on the clutch cover seen here:
      10. Remove the plastic gear.
      11. Push out the metal pin and remove the washer underneath as seen here:
      12. With a screwdriver or whatever your preferred tool, remove the “E” clip as seen here:
      13. After removing the “E” clip push the water pump shaft out of the clutch cover.
      14. You will now have the part in your hand that needs fixing. Remove the porcelain gasket at the bottom of the shaft by blowing it with compressed air. Don’t not pry it with a screwdriver as it could damage the gasket. Mine was stuck fairly well so I sprayed some WD-40 on first to loosen it up.
      15. If you used WD-40 clean the shaft and gasket with some brake cleaner and then apply the RTV sealant to this area (I reused this pic as its perfect):
      16. Push the gasket back down flush on the shaft wiping away any excess RTV that may flow out.
      17. Reassemble the shaft into the clutch cover in reverse order as listed in steps 9-13.
      18. Place your new clutch cover gasket on the engine and then place the cover back onto the bike.
      19. Put the bolts back into the clutch and water pump cover and tighten equally. I could not find a torque setting for these in the manual so I snugged them evenly.
      20. Put the oil filter or a new one in the bike and put the oil filter cover back on.
      21. Re-attach the brake lever and tighten the bolt to 21 ft lbs. Be sure to install a new cotter pin on the backside of the bolt.
      22. If you drained your oil, refill the crankcase with the proper amount. If you didn’t drain the oil be sure you have enough in the crankcase from oil lost from removing the clutch cover.
      23. Let bike sit for 24 hours to let the RTV set up before adding coolant.
      24. Re-attach the coolant hose to the top of the water pump and tighten the hose clamp.
      25. Fill the radiator with a “Silicate Free” anti-freeze and put the radiator cap back on and tighten the radiator cap screw.
      26. Put the radiator cover and your skid plate back on the bike.
      27. You are done, go ride!
      This post has been promoted to a wiki
